GE Profile Spectra JGBP90 Gas Kitchen Range Logo
Chris Watson Posted on Dec 16, 2017
Ihave a GE XL44 self cleaning oven. The self
Ihave a GE XL44 self cleaning oven. The self cleaning works, but not the normal oven section. The ignitor has continuity, but only has 120VAC when turning knob to self cleaning. The 120VAc shuts off when turning back to oven temps. The indicator light turns on but no ingnition. My model is jgbp30aea4aa. What next?
5 Related Answers
Anonymous
  • Posted on Dec 25, 2006
SOURCE: self clean light blinks when you turn oven on (oven does not work)
I had this same problem with mine (still posted under unsolved) This is the simpler model with the old turn style knob and the lever you slide over to lock the door for cleaning What I think (keep in mind I know little about ovens, more about cars) is that the switch that tells the oven the door is latched is staying engaged, and this is part of the lever mechanism. I cleaned and lubed this mechanism (obviously I would guess you want to use a food safe lubricant) and then moved the lever several times with the oven on so I could see if it turned on. After a few tries the cleaning light went off and the oven light came on. No, its not really a technical answer, all indications to me where that the problem was in the switch which is part of the latch mechanism. Good luck
A
Anonymous
  • Posted on Mar 26, 2007
SOURCE: ge spectra xl44
It was the igniter. The gas would go higher and then lower. The oven would take an hour to heat up. The new igniter did the trick. Thanks for your help and that link to the new part.
Anonymous
  • 213 Answers
  • Posted on Nov 19, 2007
SOURCE: Need to clean oven GE true temp self clean
the oven temp sensor is bad. replace temp sensor to solve problem
Anonymous
  • 750 Answers
  • Posted on Sep 25, 2008
SOURCE: ge oven profile spectra xl44
Hello ,
Welcome to fixya.
I'm Huuum and happy to assist you,
You asked, is there anyway to bypass the oven lock or bypass the self cleaning mode to get oven working?
Why do you need to do this?
If the door lock is stuck in closed position and preventing you from using the range?
You may free this by following this procedure.
Threat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects most problems!.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the lock switch itself is bad and if you think you can bypass it then you may as well change it. Same labor!!.
Let me know how it works out.
Huuum
Please remember to leave a rating.
Anonymous
  • 23 Answers
  • Posted on Jun 20, 2009
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
1helpful
XL44 oven. How do you latch the oven closed for self-cleaning...there is no lever.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
I have a Ge Profile XL44 range/overn but I can't find the manual - how do I use the self clean. I see the button to press but do I take out the racks before I turn it on?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!!
I have a GE spectra xl44 stove model #jgbp28bea2ct, when I turn on the oven the clean light winks and the oven does not heat up. please help
heatman101
SELF CLEANING WILL NOT ACTIVATE, GE XL44 MODEL JGBP32AES OVEN
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Ge xl44 self cleaning gas oven willnot come on
heatman101
I have GE XL44 range. How long should i run self
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!!!
I have a GE xl44 gas oven/stove. I cleaned the
Change the Temp sencor for the self cleaning
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
