Nokia N95 Cellular Phone Logo
Anonymous Posted on Mar 03, 2010
Configure Nokia N95 to work with SIP with my MWEB account
I have a Nokia N95 and a SIP account at MWEB (South Africa). I have successfully used SIP from my N95 via the FRING client but have not been able to use the N95's native SIP capability. The FRING client is heavy on the battery and not convenient to use. I have loaded the Nokia application "SIP VoIP Sett" to give me access to the additional SIP settings and have tried various configurations but without success. Is there a way to trace the setup ‘conversation’ between the N95 and the MWEB SIP server and determine the error conditions?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 02, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
336
Points
How to set up nokia E5 for fring and sip to give me access to the applicational sip setting s
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1170
Points
6
Code for IMEI 359757002671065
From South Africa in Sydney - cannot send e- mails
Check that you have a service provider. Also check that you have email applications installed. Your service provider can help there. Check that you have Chat service using internet, assuming that works too.
3helpful
How can call with nimbuzz
SIP (Session Initiation Protocol) is a protocol used to establish, modify and terminate VOIP telephone calls. Using SIP, you can make cheap calls to a landline and regular mobile phones. With Nimbuzz SIP support, you can make Internet calls via the Nimbuzz Phonebook feature by adding any SIP provider you already use. Costs depend on your SIP provider rates.
SIP calling is mostly used to make cheap international calls.
You can go to Options > Settings > SIP Accounts to register an account.
After that you can place VoIP calls via the Phonebook.
User Fring if you want to make free calls. It works on Yahoo Messenger and Gtalk so you can call your buddies available on Yahoo! or Gtalk.
1helpful
How to do internet settings manually on nokia e71
BEFORE YOU BEGIN, please note the following:
On the Nokia E71 some of VoIP settings are hidden by default, and you will need Nokia's new VoIP SIP application.
This application can be used to configure VoIP settings on your Nokia. You can create new VoIP profiles and modify the existing ones, and create and modify VoIP parameters and NAT/Firewall traversal settings and that are normally not visible on the device UI, such as codec settings and SIP domain-specific NAT/FW settings. It is also possible to save all the VoIP profile settings to a text file. It also enables VoIP over WCDMA which means you can make VoIP call over 3G Internet connection.
Using your PC you can download free Nokia SIP VoIP application from here or you can check Nokia web sitefor latest version.
Extract and install SIS file using Nokia PC Suite software on your PC.
Once installation is complete you will be able to see "SIP VoIP Settings" application under Applications menu on your Nokia, which you will need in STEP 5 of this configuration guide for better voice quallity or enabling VoIP over 3G Internet connection.
Here you can find Nokia E71 SIP settings for voip setup and SIP client configuration guide with VoIPVoIP service.
STEP 1 Go to Tools / Settings / Connection / SIP settings. Create the following profile
Profile Name: VoIPVoIP Service
Profile: IETF Default
Access point: (your WLAN AP name)
Public user name: [email protected] ( Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. When recorded your phone will show sip:[email protected] )
Use Compression: No
Registration: "Always on "
Use Security: No
STEP 2 You do not need to enter Proxy Server settings
Proxy Server Address: none
Registrar Server:none
Realm: none
User Name: none
STEP 3 Enter the following for Registrar Server settings
Registrar Server: sip3.voipvoip.com (When recorded your phone will show sip:sip3.voipvoip.com)
Realm: voipvoip.com
User Name: 5551231234 (Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. )
Password: Enter the password that you chose when you signed up for the service.
Transport Type: UDP
Port: 5060
STEP 4 Go to Tools / Settings / Connection / Internet Tel. Settings
Create a new profile for "voipvoip"(555123xxxx), name it "voipvoip"
Choose "voipvoip" as Preferred profile
STEP 5 For better voice quality or in order to be able to make VoIP calls over 3G internet connection you need to use Nokia SIP VoIP Application you installed.
Go to Applications on your phone and click on "SIP VoIP Settings" application. Choose VoIP services/VoIPVoIP (or the name of your VoIPVoIP account Internet profile.)
Click on "Profile Settings" and find "Allow VoIP over WCDMA" option and change it to "ON" This change allows VoIP over 3G connection on Nokia phones.
For better voice quality go to Codecs and delete all codecs except G729. There should be only G729 codec left under codecs setting
STEP 6 Reboot your phone. Once your phone is back on it will automatically register to VoIPVoIP.
Once it is registered you can start making calls.
Default call type: To switch between normal GSM calls or VOIP calls, navigate to Tools / Settings / Call / Default call type. Select Cellular to make normal calls to the phone number or Internet to use VoIP to call the number or address
Make Calls!
To dial any phone number that is part of the NANP (North American Numbering Plan), you must dial:
1 + Area Code + Phone number
To dial any phone number that is outside of the NANP (North American Numbering Plan), you must dial:
Country Code + City Code + Phone number
For example if you want to call Brazil (country code 55) phone number in Rio de Janeiro (city code 21) you must dial 5521 and phone number. + sign can also be used and number can be dialed as +5521xxxxxxx
BUT RATHER THAN FOLLOWING THESE PLS CALL TO YOUR CUSTOMER CARE THEY WIL GIVE THE SETTINGS. SAVE THEM. THEN FOLLOW THE INSTRUCTIONS. THIS DOES NOT COST ANY COST. PLEASE TRY THIS
1helpful
4answers
Recovering mxit pin
Try e-mailing [email protected]
The sms to 34006 only works with cell numbers that are in South Africa. If you're there & are getting a blank reply from your service provider, this means the number you SMSed from is NOT registered to MXit.
Answer
If this were something in the states it might be easier to figure out.
The only thing I could suggest is make sure the firewalls are turned off.
Is this a broadband or dial up connection?
Nokia n95 8 gig..
You should obtain a SIM card from a local service provider in South Africa. If that still does not work, it could be that the SIM is locked. See the following links to unlock the phone:
http://www.unlockme.co.uk/unlockme.html
http://unlock.nokiafree.org/
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
