What are you tring or want to reset? Try the rest botton on the control pannel. Or give some more info. like the error code being displayed, then I may be able to help.
E701 is reported when the controller is unable to communicate with the IOT(image output terminal).The following check might save some further troubles. 1.If the the controller is pretag 2,connect a terminator to the SCSI port marked "HOST" 2.Disconnect the IOT,power up the controller,press the reset switch on the controller board and allow reset cycle to complete,power down,reconnect,insert floppy firmware,power up. 3.Down grade to firmware 2.7 4.Check PSU +5V and +12V at the pcb. 5.Check HD drive present on the config printout. 6.Check reset switch if not stuck in on controller. 7.Check controller to IOT cable in good condition. 8.Replaced the flash SIMMs And lastly if all the above fail to cure the fault then replaced the controller board.
