Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
Posted on Mar 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water coming out of adjustable air vent behind wall of tub
US Parts Center
Level 3:
  • Whirlpool Master 719 Answers
  • Posted on Sep 06, 2010
US Parts Center
Whirlpool Master
Level 3:
Answers
719
Questions
0
Helped
284270
Points
1972
One or more of the jets are turned off. i would suspect someone is plugging the jets off which causes water to go backwards in the system and the water goes out the air controls. solution: check the jets to make sure the jet faces are turned on and/or tell someone to quit plugging off the jets when they are in the tub.
Frigidaire stack washer and dryer water pump air bursts
follow this steps and use the common sense. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water
Why does the air conditioner leak water from behind the unit. My air conditioner is placed in a wall and the back end of the conditioning unit sticks out inside the garage. I have ventilation by...
It is normal for an air conditioner to leak water out the back. This water is actually the humidity being taken out of your house. Being vented out in to the garage is always an issue with condensate water. I have seen some people take a funnel and run a hose outside the garage somewhere. Keep the vent closed. It will be harder to cool the house with the vent open because it lets outside air in to the house.
2answers
When do you need to vent a bathroom sink?
You always need to vent a sink. If you do not vent the sink it will create a vacume and **** water, or air from the nearest fixture.. example, if you connect to the sewer line near a bath tub, when you run the sink water it will **** air from the bath tub drain. If it sucks a lot of air, you will smell the sewer odor since the water is no longer blocking it.
If you cannot run the vent to the roof, there is an in wall vent valve called a studor vent that may work. Get with someone at Lowes or Home depot to show you one.
Feb 09, 2011 • Home
We have two new faucets in tub, They are both 144910 the question is how do we turn the force of the water down? The plumber that installed them could'nt help. Please advice what to do. I turned the hot...
if the water pressure is high all thru the house then turn down the valve on water main or or if well adjust cut in -cut out or valve down a bit if just high at tubs can adjust valves on water line can install a water saver behind shower head or if u have access to the valve body in wall there are adjustments on both sides where the water lines come into -----if this is about temp in ur paperwork advises how to adjust the anti-scold --remove handle and trim will see a blue and red plastic clip on valve stem adjust till temp is comfortable
Mold behind vents
Fill a spray bottle with a 25% bleach to 75% water and spray the front coil which will allow it to circulate with the air, you may want to spray some in the vent before hand with the a/c off. You can take it out and wash it with a water hose if its really bad.
I a leak under my tub, think it's from the shower, it doesn't leak with a full tub of water or ewhen you empty the tub, but when you're in the shower a flow of water comes out under the shower piping side...
Check out the faucet plate mounted on tub side for a good seal. Water can leak down this plate causing it to look like the valve is leaking.
When you are in the shower it splash's water against the valve and water will run down behind it. Check the tub spout and if you have tile check the chaulked joint where tub and wall meet.
Jun 02, 2010 • Plumbing
3helpful
Sewer gas smell every time the tub is emptyed
If you are getting a gas smell when the tub is emptied it is because you either do not have a big enough vent pipe or your vent pipe is plugged.
I have seen cases where a vent pipe has sagged enough to trap condensate and rain water and plug that way. Find what is the actual cause can be difficult and time comsuming. Often times the cause is hidden over a ceiling or behins a wall.
I have fixed them already but installing a "cheater vent" or "Studor" vent under a vanity cabinet that is close to the tub. These vents are just a one way valve that will let air into the line but not back out.
Your problem is because when the water goes down it replaces some air with water volume. That air comes bubbles back up the piping and creates a smell.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Water not coming out of door dispenser. Have to go inside and use Hair Dryer on the inside water lines on the back wall of fridge behind the vegetable draw to thaw. Fridge is set at recommended...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Water fill levels seem too low
wouldn't want to try to adjust ..can be risky and tough to get right ..water level usually comes to top row of holes ..be sure drain hose is as high as tub top to prevent siphoning
Top Whirlpool Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
