I scan my camers memory card it shows 62 viruses it removed after that it shows some extra files . after some time this card not opening photo file it also change name of folded
Re: I scan my camers memory card it shows 62 viruses
How are you getting viruses on your card? Are you using your computer to add pics to the card? If so, that's the problem. You need to format the card in the camera.
It seems that your phone memory card contains the virus.So scan your memory card using the anti virus installed in your machine.You can scan you memory card for antivirus using the Avira anti virus.Please download the anti virus from :
Install the software in your computer.Remove the memory card from the phone and connect in your machine using the memory card reader and scan the card for viruses or malwares.
Yo! i will advice you format the card rather than scan because you can only scan if you have antivirus on your phone which is not possible with many phones. so please format the card and you will get rid of it.
If your memory card is showing memory card corrupted both on the phone and your computer, then it means there is a problem with the memory card. Most likely the memory card would have been corrupted by a virus.
What You will have to do is to try to run an anti virus scan on the memory card. To do so, when You connect the memory card to the phone, You will have to right click on the memory card, then select scan using the anti virus of Your choice. Then it will scan the memory card and wipe out all corrupted files and viruses.
After doing so You can format the memory card before using it again.
If it does not work, then it means the memory card is damaged beyond repairs.
http://www.avira.com/en/free-download-avira-antivir-personal? Download the .exe file from the link.
These are executable files. If these file are in your memory card, they must be viruses if they are not applications you downloaded. You will have to scan your memory card with an anti virus, if that doesnt work, backup the files you need on pc, then format your memory card and everything will be deleted. If the files are in your phone memory, master reset your phone to factory settings and the files will be removed. Back up all your files to the memory card or pc before master resetting.
Your card is showing signs of improper removal or virus infestation. I would run a virus scan on it at once, back up any remaining data (after scanning of course), then follow the instructions when you remove the card from your computer. Not shutting down the card before removing is similar to turning off your computer without shutting down first. Usually it's ok, but it can cause data loss.
