Note - You must have an Armature License to legally perform this conversion.
1.
Remove bottom cover from radio.
2.
On the main PCB, locate J33. (See diagram above)
3.
Locate wires on pins marked "P5" (yellow) & "P6" (grey).
4.
Cut wire on "P5" (yellow) and install a SPST switch in line.
5.
Cut wire on "P6" (grey) and install a SPST switch in line.
NOTE:
By using two of the function switches available on the radio will eliminate the need for two new switches to be installed and mounted.
The first thing to check in this is the mic. If the mic is fine, then the next thing would be to check the final transistor. If it blows, then you will not transmit.
if made in the same year they should..they all are same or similar radios. contact ranger usa.. they make 90% of cb's and exports they can get you to someone. that can order the parts.. we are in texas. and can also order from ranger.. just let us know. radiotx on hwy 95 & fm 93 listed under ranger..2547184042also if you need us.. call voicemail or text. with phn # and we can get back to you. our phone doesnt always have a signal inside so text's or voicemail with a call back number..
You can get a pa speaker at Radio Shack.....in the back of the radio there should be a pa jack, just plug it right in and put your radio on pa function, and you should be ready to go.....hope this helps....
