Lens error, restart camera error comes up and lens
I get a "lens error, restart camera" error comes up and lens makes clicking noise a it comes out or zooms in.Can I open this camera up and do a amateur repair on it?
Re: lens error, restart camera error comes up and lens
Not able to get opendand the sensors of the lens unit not able to conform the position of the lens,is due to the damage of the gears/mechanism of the lens fuction,so get it serviced/replace lens unit
This has to be THE most common failure mode for a digital camera. Some
common error messages that might show up on the LCD's of cameras with
this problem include "E18 lens error" (older Canons), "ACCESS" error
(Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error,
restart camera" or just "lens error" (nearly all camera makers lately
use this variation). Some cameras might show nothing at all, but merely
make a beeping noise as the lens goes out, then in, then the camera
shuts off. Sometimes the lens won't even move.
Some problem with the lens. Look at the lens as it comes out, and listen as well. If it does not come out at all, then internal problems exist. If there are noises, problems are inside. If the lens comes out but is not at a straight angle, you may be able to fix it by carefully pulling on it as it extends.
If nothing else, sell it on Ebay as a repair camera. List it like this: Canon PowerShot A430 Digital Camera as is repair
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
zoom lens is not coming out when switched on
