It's a gray area, your word against theirs. Unless you can find 100 people who have had the same problem, you have little chance of making a successful claim. Hopefully, the time will soon come when induction charging and Bluetooth will make it possible to build completely sealed underwater cameras.
SOURCE: The waterproof door Fuju fine-pix Z33 WP has broken
This might be of big help logged on to this link : http://www.fujifilmusa.com/support/ServiceSupportContact.do
they do have the repair options and where you can sent that item for repair.
ERNZ
SOURCE: i have a waterproof fuji camera and i cant figure
Press MENU/OK to display the menu. Use up/down to select Setup. Press right to display the Setup menu. Select Date/Time. Use left/right to select a field, up/down to change it.
SOURCE: My Fuji XP Waterproof camera says card protected
It's the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
