Roper Electric dryer- Model: RED4340SQ1
TYPE:D433-ELE-2406026-FM54
Dryer tumbles but wont heat and timer knob doesnt rotate. Exhaust vent is clear of lint and is blowing cold air.
Good day,
Timer woun't run if there is n heat.
1. Check to see you are getting 230 volts to the machine. The motor uses only 115 so is not a good indication.
2. Remove back cover. You will need an ohm meter to test the components.
A. In the center bottom is a skinny white bakelite device held on with one screw. Remove one wire and check. It should check zero ohms. If not replace.
B. On the bottom right is a canister with the heating element terminals sticking out. They should test at 30 or less ohms. If not replace the heating element.
C. There are about 3 other limit thermostats in the area you're working. They should all check at zero ohms. Replace as needed.
Below is a tutorial on changing a heating element.
http://www.applianceaid.com/wp_element.html
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
replace heating element
