Philips CD1503B/17 Phone Logo
Anonymous Posted on Mar 02, 2010
Pls reg h/s
Hallo. I´m having problem with my phone (Philips CD150). On the screen says PLS REG H/S.
Can you please help my through my problem
  • Anonymous Mar 22, 2014
    he Alcatel Versatis E10
Anonymous
Level 3:
  • Master 569 Answers
  • Posted on Mar 02, 2010
Anonymous
Master
Level 3:
Answers
569
Questions
0
Helped
196104
Points
1789
Follw the instructions below for the hanset that is not regestered.
The full manual can be downloaded from http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?mode=search&session=20100302153603_80.3.156.26&scy=GB&ctn=CD1501B%2F05&ds=CD1501B%2F05&slg=ENG&qslg=on&searchtext=manual&submit=Search
and select 'User manual'
To register your handset manually:
The Master PIN is required before you can register or unregister handsets.
Note
By default, the Master PIN is 0000.
On the base station, press and hold .))) for approximately 5 seconds. LED indicator around the Play/Stop key on the base station blinks.
On the handset, press (menu) key, scroll (using up or down arrows key) to ADVANCED SET and press (OK), scroll to REGISTER and press (OK).
Note
If no action is taken on the handset within 10 seconds, the registration procedure will be aborted. If this happens, repeat Step 1.
Enter the Master PIN when prompted and press (OK) to confirm.
Note
By default, the Master PIN is 0000. WAITING_ _ is displayed on the
screen.
Note
boy Bentulan
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 04, 2015
boy Bentulan
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
4754
Points
9
To reset the philips CD150 is press the pair button of the base for 10 seconds and while pressing the pair button of the base unit, press menu of your handset at the same time then scroll to advanced set, the OK, then scroll to registration, then OK, then type the master pin# 0000 , then release the hand from base unit pair button, then press OK button of the handset. then display say waiting ... wait until the display show the welcome or country. then it's done! your phone is ready to use.
PLS REG H/S ????
Talk to Philips support: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
1helpful
Alcatel mobile getting message as pls reg h/5
Pls reg h / s error message for ionizing phones uniden
This error cannot be fixed at all. Please help me help
4helpful
6answers
Registration key for boldbeast call recorder 3.40
my imie is 355740021025590 . Please mail me registeration code for boldbeast call recorder 3.40 for Nokia 5320 Xpressmusic.
Jan 30, 2013 • Cell Phones
ON THE SCREEN ITS SAYS PLS REG HI5 I THINK
whats the phone model? brand? pls complete your question.
4helpful
Pls reg h-s philips cd 150problem
Hi, there,
I just have the same problem here in Taiwan. Now it's solved.
First, make sure phone line of your cordless phone is connected. Then, get to the advanced settings and key in default pin number (mine here is 0000), but don't press OK here. At the same time, push the "radial sign" in the center of CD 150 bracket for 3 seconds so it can deliver signals. Meanwhile, press OK button on the phone and if it's working, you will see
"waiting" and not long after that, no more PLS REG H/S.
Hope it's helping :)
also see :http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?mode=search&session=20110103075755_59.112.120.112&scy=TW&ctn=CD1501B%2F96&ds=CD1501B%2F96&slg=ENG&qslg=on&searchtext=registration&submit=Search
[email protected]
6helpful
3answers
Have new Philips CD150 phone. It say PLS REG H/S, tried the Registration through menu with default pw 0000. Still just waiting and waiting.
not sure if you got your phone problem fixed . however i had the same problem and to fix it you sit the phone on the base unit of the phone and press the menu button then go to advanced settings and then registeration . enter in 0000 as the pin and then 'waiting' will appear and your problem should be solved.
Reg.key for smartmovie v.400
I need ur phone IMEI code
See it by *#06#
And send to me
[email protected]
Feb 24, 2009 • Nokia 6600
1helpful
Register handset
drop each phone one at a time into the base... not the charger.. the main base... you will notice the charging light flicker... move on to the next phone... they should all be registered when you are done
Robert
Please take a moment to rate this solution thanks
20helpful
6answers
Phone guardian reg.code
more information is needed pls
Top Philips Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
