NEC Dterm DTP 16D-1 Corded Phone Logo
Posted on Mar 02, 2010
How do i forward a call to a cell phone? - NEC Dterm DTP 16D-1 Corded Phone
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 03, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
887
Points
I believe your landline carrier just needs to have the capability of call forwarding (ie we utilize Verizon for our business). We also use the call forward feature by: picking up line, (hear dial tone) dial *72 [ then phone number you want calls to forward to, even a cell]. To discontinue: pick up line (hear dial tone) dial *73
LG306g Tracfone cell phone - how to enable and disable call forwarding? I did it two yrs ago and can't remember now.
Call Forwarding
  1. To enable Call Forwarding, tap the "Phone" icon at the bottom of the screen.
  2. Dial *72, followed by the area code and phone number that you want your calls forwarded to.
  3. Tap the "Call" icon. The call will be connected, and then, disconnected. ...
  4. To disable Call Forwarding, dial *73. Tap the "Call" icon.
Call Forwarding - Tracfone support - TracFone Wireless
Dec 01, 2020 • Cell Phones
I forwarded my cell phone calls to my house phone. I cannot deactivate call forwarding. I have a Samsung S7
  • 1.From the home screen, tap Phone
  • 2.Tap More
  • 3.Tap Settings
  • 4.Tap More Settings
  • 5.Tap Call Forwarding
  • 6.Tap Always Forward
  • 7.Enter the number you would like your calls forwarded to and then tap Enable
  • 8.To disable call forwarding, swipe down from the top of the screen
  • 9.Tap the Call Forwarding notification
  • 10.Tap Always Forward
  • 11.Tap Disable
Samsung Galaxy S5 How to Setup Call Forwarding
1helpful
I want to forward my cell phone text to another cell phone
The only way to forward text messages from one cell phone to another is to manually go into the message>options>forward. You cannot forward text messages like you can phone calls. It is not possible right now.
Can I divert calls from this phone to another phone? Thanks MArk David
  • Figure out if your particular cell phone model has the option to forward incoming calls. You can do this by visiting your cell phone manufacturer's website or reading the manufacturer's manual that came along with the purchase.
  • Access the "Settings" menu on your cell phone and select "Phone Settings" menu.
  • Select the "Call Forwarding" option in the "Phone Settings menu. This option is usually found at the bottom of the "Phone Settings" menu. Selecting the "Call Forwarding" option gives you access to call-forwarding controls.
  • Switch on the "Call Forwarding" slider. The default position is off.
  • Insert the phone number you wish to forward your calls to in the "Forward To" field. This field most commonly lies below the "Call Forwarding" slider.
  • Exit the setup menu by pressing the home button. You may be asked to confirm/save the changed settings depending on your cell phone model.
  • Make a test phone call to the cell phone number on which you just enabled the call rerouting option. If the call is forwarded and received on the number you entered, it means that the "Call Forwarding" option has been activated.
  • 0helpful
    I cannot forward all calls to my cell phone.
    Which system is the phone on? You may not have permissions to forward out to a cell.
    2answers
    Call forward to cell phone
    Who provides your dial tone? You will have to find out their code for forwarding calls to a cell.
    SBC/AT&T/Ameritech uses #72, then dial the number you want to forward to
    3helpful
    My cell phone is not working and I want to forward my calls to my husbands cells. I have a Alltel Razor phone. How do I set up the call forwarding
    If your plan allows forwarding these are the steps
    to forward *72# XXX-XXX-XXXX (the number you want to forward to) send
    to unforward *720# send
    hope this helps
    Sep 04, 2008 • Cell Phones
    1helpful
    Call Forwarding
    tell her to dial *72 followed by your home phone number then press send on your cell phone. she will hear a stuttering dial tone. the calls are now being forwarded. when you get ypur cell phone, press *73 then send to deactivate the call forwarding.
    wg
    Trying to Forward Forwarded Text Messages to Email
    Try saving the pictures to your phone first than sending them to your e mail
    Top NEC Lands Phones Experts
    ADMIN Andrew
    ADMIN Andrew
    Don A
    Don A
    RAJA NADEEM AKHTER
    RAJA NADEEM AKHTER
    Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
