Black & Decker NPP2018 18 Volt Cordless Pole Pruning Saw Logo
Posted on Mar 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost maintainance instructions for NNP 2018 pole pruning saw Chain jammed some teeth are out of line
Anonymous
Level 3:
President:
  • Master 2,220 Answers
  • Posted on Mar 02, 2010
Anonymous
Master
Level 3:
President:
Answers
2220
Questions
Helped
1384486
Points
7625
It sounds as though you have bent drive links? I would probably replace the chain. Burrs we can help, see Chain Repair here:
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
The instruction sheet is available here:
Black & Decker
Go To “ServiceNet/” link
Bottom of center column “Need a Manual?” Enter model number, “YourModel” in window.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
2answers
How can I use a gas pole saw?
Congratulations on getting you a new gas pole saw! A gas pole saw is undoubtedly the most powerful of pole saw types. It uses gas for operation, heavy-duty bars, and chains and is effective for a longer working period. Since it is the most powerful; you can put your faith for pruning heavier and larger branches and trees.
So, you have chosen rightly. But, it is a matter of concern, if you do not know how to use a gas pole saw. Let us help you with this matter.
BEFORE YOU START
  • Make sure that the pole saw is safe and prepared to be used. The faulty ones can lead to a serious accident.
  • Clear the area where you would use your pole saw and where the limbs would fall. Any hazard should be cleared at once.
  • Be aware of the weather because the windy or rainy weather can turn your pruning into a dreadful experience.
  • Cut only one limb at a time
  • Avoid cutting branches that are thicker than 8 inches. Take expert's help in this matter.
  • Be aware of the kickbacks.
  • Always maintain the right balance and base. Hold the saw firmly and stay at your place rigidly.
These instructions should be taken into account before the start of trimming. After you follow the instructions given above, it is time to move towards pruning process. The steps below lay out how to use a gas pole saw.
STEP 1 As you hold the grip of your pole saw and make a balance of your position, make few jump cuts underneath the branch you want to cut off. Jump cuts are a necessary technique which is used before the final cut. It reduces the weight of the branch that makes the final cut easier. It can be physically challenging to cut from underneath. So, always pick a pole saw equivalent to your weight bearing capability.
STEP 2 Extend the height of the pole saw based on the height of the branch. Hold the pole saw vertically, take it up to the branches away from the ground and never forget to hold it properly. Adjust its position and let it rest on the branches. In the meantime, you can ensure your position too. Always keep the pole saw at your chest level.
STEP 3 Now, begin to cut perpendicular to the limb and try to make deep cuts as much as you can. Deep cuts will let you make the final cut and other cuts easier. It will also allow you to make faster cutting strokes. Readjust your position, and the pole saw if you face any trouble.
STEP 4 The last step is all about your safety. Check where the limbs are falling and move from that place as early as possible.
Do not lose hope if you fail the first time. Keep trying until you reach your full potential. Clean the work area after trimming is done. So, this is how you can use a gas pole saw. Keep pruning and stay safe!
More details open the link Guide on How to Use Gas Pole Saw
Apr 11, 2018 • Garden
How to clean pole saw blade?
Remember the time when Pole Saw did not exist? People used to use a ladder to reach the distant twigs and branches of trees. But, so pruning used to be a very tedious job which is now an exciting task to accomplish. Now, you do not have to think of pruning such branches with much difficulty because you can get a pole saw. It reliably offers a smooth cutting experience and makes pruning easy and convenient.
If you have a pole saw, you need to understand that possession begets responsibility. So, you should take excellent care of your pole saw. Moreover, its longevity and efficiency would reduce to some extent when you stop caring about the pole saw. Cleaning pole saw blade is a crucial part of maintenance.
So, here goes your guide to clean a pole saw blade.
  • The first and foremost task is to clean all the impurities, dirt and tree debris. You can do it with the help of wire brush. To remove the oil residue, brush it with a rag or toothbrush and degreaser.
  • Many people prefer citrus cleaner over oil. A citrus cleaner is a versatile cleaner that can be used for cleaning anything in your house.
  • If you are using any degreaser product, mix it with water in a container and put the blades into the container.
  • Let the blade soak into the water for few minutes, scrub it with a rag, rinse it properly and let it dry or wipe the water from the blades.
  • Disassembling the pole saw is required before you clean a pole saw blade and put the blades in the container. For this purpose, remove blades from the pruner. You can take expert's help for this or unscrew the blade.
  • Put the blade on a table where you would clean the blade and keep the edges facing up.
  • Take a sharpening rod and push it forward only between the two teeth. This will file away the meat and sharpen the blade. Keep doing this for few times until you see the filings being developed on the back side of the blade. Make sure to file all the teeth on the blade.
  • The back side of the blade should be rubbed with a file as well. It is required to remove the burrs from the blade.
  • After sharpening coat, the pole saw blade by spraying oil on it to prevent rust and corrosion.
More details Guide On How To Clean Pole Saw Blade
Apr 10, 2018 • Garden
2answers
How to clean a POLE SAW BLADE?
Do not forget to sharpen the blades with files that fit appropriately in the teeth. Diamond and whetstone files are being widely used for filing. So, this is how you can clean a pole saw blade and maintain it also. It does not take much effort. Invest your time to avoid replacing your favorite pole saw in the future.
Where can I buy a long pole saw?
If you wanna buy the best pole saw in 2018 go to the link The Best Pole Saw In 2018 Practical Overview of Top Pole Saws
I think it can helps you
Mar 12, 2018 • Garden
What is the Best Pole Saw in 2018?
Remington rm1025sps is the best pole saw in 2018. Excellent value for the price. It's very powerful which made tree trimming a breeze. Awesome versatility in the fact that you can convert it from a pole saw, to a hand chain saw in less than a minute. More details go to the link The Ultimate Remington Electric Chainsaw Reviews
Mar 11, 2018 • Garden
6answers
Are you able to sharpen a chiansaw by hand?
It is very possible to sharpen a chainsaw by hand, but you want to be very careful because even a dull chainsaw can do a lot of damage!
http://www.wikihow.com/Sharpen-a-Chainsaw
Sep 17, 2013 • Garden
Wondering what size file to use to sharpen an MCP1510
McCULLOCH MCP1510 is not a good pole saw. You can't easy to use with this pole saw. If you want to find the best pole saw in 2018 go to the https://thebestpolesaw2018.yolasite.com/
1helpful
Battery fully charged but pole prunning saw does not work at all poles are connected properly
You do not mention the model number.
Honestly, I had never used a pole saw, but I needed to cut down a lot of tree branches and Black+Decke worked wonderfully. With it being cordless I could easily walk around my entire yard without worrying about it. The chain does loosen after cutting through several limbs, but it's super easy to tighten back. It's easy to assemble.
More details Practical Black and Decker Pole Saw Review
Hello! I have a Black & Decker Cordless 18 V Pole saw and I need a replacement chain. In the Instruction manual it's listed as: Replacement chain # 62338200 I can't find it in any site.
You need to know the size pitch and brand of the chain. See if it has a name on it anywhere. It may have a pitch # stamped on the side. My remington uses a Oregon chain.
Check the chains at walmart and see if they look the same. You may find a cross ref on the package that will give you another part#
Another option is to replace the bar and chain with a new Oregon Replacement Bar & Chain Combo kit.
See this site for examples.
try this cross ref chart
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
