In your phone there will be a inductor antenna which receives signal. The inductor might not function properly. Contact service persons for that. But before tat in settings - Network selection select manual and check if it shows any networks. If it shows then the area has limited or no coverage.
Really cant tell why because you havent mentioned much! Anyway if your cellphone is locked and you have inserted a different SIM card from other network provider then you wont get signals. For that you need to get your cellphone unlocked first! Visit: Smartphoneunlockers if you have this issue or drop a mail at [email protected]
Try this first
1. try to cover up any part of your phone with your bare hands. Look for a spot where the phone signal gets weaker if you cover a particular area. If that is the case, then you simply need to hold the cellphone in another position.2.Second, try to change your position or location. There are many factors that affect cellphone signal strength, one of them is the space. If you are inside a closed location, go out and see any improvements in the signal.3.Third, you can try to detach the SIM card from your phone and turn it off. After 5 minutes, put it back and see if the phone no signal problem is still going on. Or, you can change your SIM card if you have a spare one with another network say Verizon, Smart or At &t.If all these cellphone no signal tricks won't work, then your phone is probably broken. Bring it to a nearest cellphone repair center.
sir please service your cellphone in the related customercare service center to check the ic of the motherboad. due to the ic problem your cellphone cannot recive the network signal.......................
i have this samsung 821sc phone from japan, twas unlocked and open line but it doesnt have smart signal in our place...it has signal for globe but dosnt have smart?wats the prblem with this? can the experts help me
A phone can't catch signal correctly if your in a remote areas where cellphone sites are not available. Try going out of the house and see if the signal strength is going good. There maybe interference and call also the network provider of your phone. Get to know if there having technical problems with there signals. Another thing, if none of this works, I suggest you go to a cellphone repair center and let a qualified technician handle it.
If your cellphone has no signal, then maybe there is no network coverage in your area or there is network problem being experienced in your place. Try to switch other sim to know that your cellphone is causing the problem or the network.
Usually this is caused by a cellphone in the area. The cellphones send a signal to the cell tower ever few seconds, when they do that, it makes it sound like the wireless mike is losing its battery, when in fact, it is the cellphone interfering with the signal. A simple test would be to power up the system when you can verify there are no cellphones turned on and try the wireless system. Then turn the cellphone on and repeat the scenario.
