We bought a used pacemaster pro plus that we set up and it runs for 5 seconds stops with the error message dead sensor. What is the problem?
It was running fine for the owner, however he stored it in his garage for a while. Maybe it is the speed sensor. If that is it can it be replaced by someone who is handy.
OPEN MOTOR SHROUD INSPECT THE COMPARTMENT ON THIS INSTANT I BELIEVE THAT THE SENSOR IS AT THE OPPOSITE END OF THE MOTOR THE LEADS GO INTO MOTOR CONTROL BOARD I WOULD FIRST UNPLUG AND PLUG THE CONNECTOR THIS WOULD CLEAN ANY OXIDATION OFF. IF NOT YOU SHOULD BE ABLE TO DO THE REPAIR
If you need to replace the sensor, you can get one here, in stock and pretty cheap.
You can get the same sensor here, cheaper and no $25 minimum order and better shipping.
Be aware that a dead sensor reading can also be a bad motherboard. I learned that from personal experience.
Exercise Equipment Optic Sensor Part Number 102955 SAME DAY SHIP GUARANTEE...
will not power up
Pacemaster 870x treadmill. Getting power. When run is programmed (time, distance, speed) there is a clicking sound then a message appears on the display screen that states "dead sensor".
