Error trying opening Obex File Transfer LG 265 script
I have a LG 265 and I have my bluetooth places on my computer for it. I've used it numerous times to put ringtones and such (using Obex File Transfer) on my phone. Just today, When I , it starts to search/load, then a message comes up saying ''error establishing connection''.
Music can be transferred to this phone using a USB cable or through Bluetooth. To transfer your song using USB cable,
You will have to connect your phone to a computer,
Be sure to have the USB cable of your phone, then you connect it to the computer,
Then you click on open file to view folder as soon as the Auto play comes up on the screen of your computer,
That way a page will open with the files on your phone,
Go to the music you want to transfer to the phone, then you right click on it and copy the music,
Go to the page where you have your music and paste it there,
That way your music will be on the phone.
To transfer through Bluetooth, ensure the phone you are trying to transfer music from has bluetooth on it. Ensure the bluetooth is on, then you follow the steps below:
Go to your phones menu,
Select the settings, and turn on your bluetooth from there,
Then you go to the phone you want to transfer the song from,
Select send via bluetooth,
It will search for the available bluetooth that is turned on,
Once it finds yours, select it and the music will attempt to be sent to your phone,
Accept it on your LG phone, then a page will load,
That way the music will be sent to your phone.
Be sure that your phone has a large memory that can receive the file, be sure also that the musics size is not larger that 7mb, if not, it might not load on your phone and says memory full. If your phone allows memory card, the moment you transfer the music to your phone, then you browse it out from your multimedia and transfer it to your memory card, to avoid the memory full error from coming up.
Hope this was helpful. Thank You for using FixYa!!
You can follow this steps for your concern: Via Memory Card 1. Remove the memory card slot cover, located on the right side of the unit. 2. Insert a microSD memory card into the memory card slot until it locks in place 2. On the SGH-i607, navigate to the folder that contains the image 3. Highlight the desired image 4. Press the right soft key for Menu 5. Select Edit (4) 6. Select Copy (2) 7. Navigate to the Storage Card using the up or down navigation keys. 8. Press the left soft key for Select.to copy the image to the memory card Via Bluetooth On the SGH-i607 1. While in standby mode, turn Bluetooth on 2. Switch the Bluetooth visibility to On On the PC 1. Connect the Bluetooth adaptor to the PC?s USB port 2. Search for Bluetooth devices 3. Select the device to pair with the PC 4. Exchange PIN code(s) on both the PC & handset to pair devices (default pass code is ?0000?) 5. Using My Bluetooth Places, select File Transfer or OBEX to view the phone?s contents 6. Copy the desired Photo file 7. Paste the file in a PC destination
Just to clarify, the Apple Iphone doesn't tranfer file data by bluetooth. So whoever sold you the handset should have mentioned this. The Bluetooth on the phone is only for use with a bluetooth earpice or carkit.
iphone dosnt support OBEX. obex is the method for file transfer. it only supports handsfree headsets. there is no method for file transfer via bluetooth, u wanna go for app "dropcopy" this is for file transfer b/w 2 iphones.
This information is from the Motorola Customer Help web pages.
To connect your phone via USB to computer and access your phone's memory card:
On your phone:
Press the CenterSelectKey
Scroll to and Select Settings
Scroll to and Select Connection
Scroll to and Select USB Settings
Scroll to and Select DefaultConnection
Scroll to and Select MemoryCard This
directs the USB connection to your memory card. Attach the Motorola
Original USB cable to the accessory port on your phone and to an
available USB port on your computer.
How do I use my own ring tones on my phone? To put ring tones on your phone using Motorola Phone Tools 4.36c and higher:
Start Motorola Phone Tools.
Choose your phone's profile or create a new profile.
Click OK to wait for a picture of your phone to appear or for your phone to be setup for the first time.
Once the image of your phone appears in the lower right of your computer screen select Multimedia Studio.
On the screen that pops up select Melody Studio.
Select a tab at the top of the screen to find a source for a ring tone. (Samples, My Melodies, My PC, My CD, My Phone).
Select an audio phone you wish to transfer or edit.
Edit the file to your taste or simply choose Transfer to phone.
The file will be put in your ringtone folder.
To transfer music to your phone via Bluetooth(The computer must have a Bluetooth Profile that supports OBEX File Transfer ): Note:
The steps you may need to use to transfer music via Bluetooth may
differ from the steps used below. A PC and a Motorola PC850 Bluetooth
Adapter were used in the steps seen below.
On your computer
Go to My Bluetooth Places
On your phone
Push Menu
Scroll to and Select Bluetooth
Scroll to and Select Setup
Turn Bluetooth Power On
Push Back (right softkey)
Scroll to and Select Find Me
Press Back several times to return to the home screen
Double click Find Bluetooth Devices
Let your computer search and find your device
Double Click on Motorola Phone (Phone's default name is "Motorola Phone" unless you have renamed it in Bluetooth>Setup>Name
Double Click on OBEX File Transfer on Motorola Phone
Computer will be prompted to enter a Passkey
Enter 0000 on your computer and press OK
Phone will ask if you want to Bond with your computer. Select Yes or No
Phone will then prompt you to enter the 0000 Passkey then press OK
Phone will then prompt to Grant or Deny OBEX File Transfer
Double click on audio Folder
Computer will now display a conversations and voicerecords folder. Copy and paste or Drag and Drop your m4a(AAC) or MP3 ring tones to the audio folder and NOT into the conversations or voicerecords Folders.
Phone will then prompt to Grant or Deny OBEX File Transfer to complete the transfer
Note:
By putting ring tones on your phone using Bluetooth or Motorola phone
tools, you may not be able to remove the ringtone from your phone.
Motorola is aware of this and in the future removing the user added
ringtones
