The Polaroid A515 digital camera can only use SD cards upto 1Gb. if you are trying to use a SanDisk 2Gb SD or a higher capacity SDHC card you will be disappointed.
My 33LF had the same problem with a 1gb Memory Card. I have replaced it with a 512mb card and it seems to be working perfectly. I was told that the capacity of the 1gb card exceeds the capacity of the camera.
Hardware of this camcorder supports up to 2GB memory card so 4GB is more than its capacity and causing error. Try 1GB or 2GB memory card in camcorder. Thanks.
No. Your
camera will accept a maximum SD card capacity of 2GB. It simply isn't
capable of handling anything of a larger capacity and in particular is
incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
The specifications on page 25 of the User's Manual state that only SD cards between 8MB and 1GB in size can be used in this camera. When I tried a larger-capacity 2GB SD card in this camera it reported that the card needed to be formatted even though the SD card worked fine in my desktop PC's SD card slot. Verify that the capacity of the SD card you're trying to use is 1GB or less, I suspect the error report about formatting is due to the SD card being larger than the camera can handle.
Only the Camera Manual will tell you the max capacity.
They do have their limits and you could a be wasting your money or even find the camera does not accept it.
Check the manual thoroughly and if still in doubt put the question to the Nikon Technical Support Team.
