ASUS Eee 4G Notebook Logo
Posted on Mar 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I re-set my wii password?
Got wireless broadband recently but only used for wii, as didn't have laptop. Got laptop yesterday and had to get new password to be able to use internet. Need to re-set password on wii to match the one given for internet - how do I do this?
Tony Groves
Level 3:
  • Master 344 Answers
  • Posted on Mar 01, 2010
Tony Groves
Master
Level 3:
Answers
344
Questions
7
Helped
126749
Points
1325
On the Wii console's main menu, click on the 'Wii button' in the lower left corner, then 'Wii Settings' then 'Internet' button, Select 'Connection Settings' you should see your wireless connection and be able to edit the password or just set-up a new connection by choosing 'connection 3'
2answers
My wii wont connect to the internet. i havnt used the wii internet for a while, but i use my computer & the internet often. it's telling me to 'confirm the SSID and try again' I cannot find...
1. Go to the Wii settings page on your Wii - it's on the bottom left hand corner of the home menu
2. Scroll right until you see the Internet option then select
3. Select Connection Settings
4. Clear all your previous internet settings, or select one of the three presets that says none
5. Select wireless connection then search for an access point
6. Select your wireless connection name (SSID) from the resulting list
7. input the password for it if you have one then follow the onscreen instructions
Hope this helps!
Recently secured wireless network with a new name and password. Can't get on Netflix now.
You need to go into your network settings for your Wii and change your Wifi network settings to reflect the new name and password. Your WIi is looking for a Wireless router named whatever you used to call it and not finding it.
Muddytrying to go to netflix, from my WII says my internet connection is not working, but my laptop in on and working.
Greetings,
Did you recently change your encryption or password on your wireless network? It may not work if you are not using one of the following encryption types:
  • WEP
  • WPA - PSK (TKIP)
  • WPA - PSK (AES)
  • WPA2 - PSK (AES)
Try re-entering your wireless settings on the Wii to match the settings on your laptop.
I am want to connect my Cricket broadband up to my Wii console
Hi Angela
The Nintendo Wii is set up to accept wireless internet.
If your broadband is set up to a wireless router, the Wii can easily connect to the internet.
Let me know if you are set up with wireless and I can give you directions to connect your Wii.
Wireless-G Broadband Router: how do i reset my password? i have a new laptop a...
you will need to contact your ISP so that they can reset the router and let you type a new password
2helpful
2answers
I can't conncet to my wireless-G broadband router
you are trying to connect to the wireless network on a new wireless computer.
When you try to connect to the wireless network, it is asking you for the password. That means your You wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
TEW432-BRP Trendnet wireless broadband router wont connect
Sounds like you need to configure the PC's USB wireless adaptor. The settings must be the same as the router. If you use a WEP password on the other connections then you need to have the same password on the USB wireless adaptor. Good Luck.
Laptop finding router but no internet connection
If you can connect directly to your virgin Media Broadband and get internet then your laptop and broadband router is fine.
The wireless router appears not to have a DNS entry and you will need to add that manually.
I suggest that you connect directly to the Broadband modem, be sure you can get onto the internet. Once you have confirmed you can get onto the internet you need to get the dns information from your Broadband modem for later.
once connected directly to the broadband modem, click start>run> then type "CMD" then click open. you will get a prompt type the following and record the DNS Server ip addresses.
"ipconfig /all" then hit enter
this will display your ipaddress information but mostly you need the DNS server ip addresses.
once you have recorded them rerun the install, but this time instead of at the end of the install where it shows the Wireless router information you can modify or change it and add the DNS server entries.
Also by default most wireless routers ip address is 192.168.1.1 and you can type that from a internet explorer and change it from there as well. I believe it's no ID or user name and the password is admin.
Good luck
New Laptop Connection
Are you connecting and configuring using wireless or cable?
2answers
Try each of these suggestions 1. username admin, password 1234, 2. username leave blank, password admin BPCS
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
