I have my memory card an want to insert into the adapter an load to the computer.. but i have no idae how. anyone help?
Dhen liturgji transflash adapter sto ipologjisti
Assuming your computer doesn't have an SD card slot....
buy this: http://www.amazon.com/Mini-Memory-Reader-Black-Compatible/dp/B001MXSG64/ref=sr_1_10?ie=UTF8&s=electronics&qid=1267478119&sr=1-10
and this: http://www.amazon.com/SanDisk-MicroSD-TransFlash-Card-Adapter/dp/B000LTN8CC/ref=pd_cp_e_2
and you're in business. :)
The second one even comes with it's own micro SD Card.
You need a USB to Flash card adapter, you push the little card into the slot, and if it is a mini card, it has to go into another card "Carrier" that plugs into another adapter, that then plugs into the PC, either through the USB adapter or a slot in PC, anyway, when you insert it, automatically, a driver will be installed, it is "Built into" Windows, now after it has done so. you can simply use it as a "Drive", meaning you can Copy, Cut, Paste.
