Question about HP Compaq Presario CQ50-110US Laptop
The display on my laptop has stopped working. All I get is a blank screen. A couple of days before lines appeared on the screen and if you moved the screen it flickered on and off....any ideas?
    Master:
  • 340 Answers
There is a ribbon connector that runs from the labtop to the screen .... eather it has become loose ro disconnected or the screen has shorted out the first of the two sounds like the problem
Posted on Mar 01, 2010
SOURCE:
Vertical line down screen
This problem can be caused by a lose connection between LCD and motherboard, however you can check it by opening the LCD or hinge bezel to ensure if there isn't any lose connection.
Oct 28, 2013 | Dell Vostro Computers & Internet
Aspire 9300 (LX.AWR0X.053) PC Notebook: I recently moved to Europe, my Acer laptop suddenl...
If your computer is in unclean place (dusty) its fan night not be able to work good and dust can get it stuck. Its not reccomended to clean laptops at home but best bring it to proffesionals.
May 03, 2010 | Computers & Internet
Laptop screen purple psychedelic visual and then screen blank
Sorry to hear that you are having problems with the computer display.
Per your description, I believe the display controller was damaged by the power surge. The laptop may need replacement of the display OR use it with an external display.
Nov 06, 2009 | Computers & Internet
Compaq f756NR laptop won't boot.
I think this is a problem with the laptop's LCD display. To verify this connect the laptop to an external display and see if it resolves the issue. If it does then its confirmed that its a display related issue. Since the issue has appeared suddenly I dont think its a serious problem. May be just loose/disconnected connectors. Should be a 10 minute job for a qualified technician.
If the external display too doesn't come on then its an issue with the graphics card and you may need to replace it.
Oct 24, 2009 | HP Compaq Presario F756NR Notebook
Sharp Aquos LC-37BX6N - no display. On switching
Off/On The Power switch sudden 4 Straight lines appear on the screen ! what is that & why ?
Oct 05, 2009 | Sharp Televison & Video
The display screen goes off when the laptop is moved
Sounds like the ribbon which runs between the screen and base is being nipped or is not making a good connection. This is a common problem. If that is the problem you may find that by adjusting the screen you can actually get the picture to show again which will confirm but obviously it will continue to happen.
Most laptops have a narrow panel above the F keys which snaps off and reveals the ribbon underneath. Check the connection is pushed in tight and also that the ribbon isn't being nipped, reposition to stop this happening. If it's been damaged then obviously you will have to replace it.
May 18, 2009 | Dell Inspiron 6400 Notebook
Laptop video failure
Sounds like you may have "hit the problem" But to me sounds like the chip itself is no good anymore. Any chance of getting a chip off another board and replacing it?
Jan 27, 2009 | Computers & Internet
HP Pavilion Dv2000
be sure that the ram is in tight, if it is try new ram
May 02, 2008 | HP Pavilion zt1170 Notebook
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
HP Compaq Presario CQ50-110US Laptop Logo
239 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
