Try a reset to this set, and check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Main system control memory IC is faulty. It should be replaced. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
You have to enter its service menu option to unlock the Hotel mode. Visit the site named 'Electro-help' for
more details. Check this LINK and select the
site named above. View it in 'Flip card' option, which can be selected
from the drop down box menu at the left top corner or the display window. It
will make search easy. Some times, the ads attached with each posts might help
you to find the availability of spare parts. There are more than 550 posts to
different brand TVs.
I have a 2005 Bonny GXP and have replaced the blower motor.
It is located under the dash, passenger side, just above the passenger toes.
It's easy to replace, and the cost of the blower has come down a lot!
I did a write-up with pictures at: http://www.gmforum.com/showthread.php?t=277509
You may have to register (for free).
Basically, remove the kick panel under the dash. Unplug the blower. Remove the vent hose. remove the three screws holding the fan, and it will drop out.
Try with that... http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom: Sound but no picture.
Cure: Master or Slave inverter is defective. It can be that the driver IC is defective or MOSF inverter transformers, or 470uF 35V C Replace driver IC BD9897FS or MOSFET's. 996500046243 IC BD9897FS 996500046242 Mosfet FDD8447L 996500046241 Zener KDZ100V
I come across this every day with LCD Tvs.What it is, is dust between the layers of the LCD. When dust particles settle behind the front layer of the LCD, and the LCD is pressed i.e when cleaned, the layers can be pushed together, resulting in a shadowy streak. If the LCD is stripped and cleaned it will be ok.
We have the same telly and had the same problem. Ours was bought Jan 08. It can be repaired, as we had ours returned from the philips repair specialist yday, but it cost £190.
