After firmware update, there is no conectivity or it's limited, and ip adress is diferent, and i can't connect to 192.168.0.1 to modem, tried many, nothing helped. Have any ideas how to restore the firmware or how to connect to the internet?
After an "Update" you will have to set the router up all again, new everything.
Below is the link to help.
http://www.jensenscandinavia.com/routers/menu_al89300/index.htm
Oh it sounds like you have "Bricked" your router... Here are some links to show you how.. to. possibly, un-brick it...
www.dd-wrt.com/phpBB2/viewtopic.php?p=189843&sid...
www.lancelhoff.com/how-to-fix-a-bricked-linksys-router/
forums.wi-fiplanet.com › ... › http://forums.wi-fiplanet.com/forumdispl..." target="_blank" rel="nofollow" >Troubleshooting -
i cannot access my router, because the ip he catches is wrong, i tried entering everything manually, but also didin't worked. Firstly it shows invalid ip, and after 40~ seconds it catches 169.***.***... something like that. And sadly no access to it, that i could reset it or change settings. Is there any way make factory reset without accessing the router? The reset button on it's back, doesn't reset it to factory settings, i tried...Maybe somebody knows what is the gateway, dns server and other details that it should be by default?
