Apple iPhone Smartphone Logo
Posted on Feb 28, 2010
When I use Internet on my iPhone it takes too much time ?
I use apple iPhone 3g and it takes too much time to load videos?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
24
Points
Restart 4 times it should work after
2answers
IPhone 3G is slow, videos won't load
please lg gb 230 securite coad breck
2answers
WHEN I TRY TO SEE RECENT CALL HISTORY THE I PHONE 3 GS REVERTS TO THE HOME SCREEN. IS THERE ANY WAY OF RESOLVING THIS?
hello,ensure you are not clicking on the key wrongly,i would advice you put the phone off and on back to see if the problem stops.if it doesn't i would also advice you ensure you close any application you are not making use of.it could also be as a result of accumulated opening of applications. if that does not stop the problem,i would suggest you get the phone flashed by a mobile phone authorized repair engineer around you.
wish you good luck,
take care.
Cannot access the internet or down load any apps onto my pay as you go i phone3g
First go to the Settings and turn on Cellular Data (as well as 3G if you wish to use 3G network). Next connect your iPhone to the iTunes and let it download cellular data file from Apple servers. If this doesn't help, contact your mobile operator to activate your internet.
2helpful
When i use the maps and sat nav on my apple i phone 3g it keeps freezing and taking a long time to load up
I am not sure how to fix that problem but I think that could be your internet slow. You have problem only when use maps and sat nav, those required the internet and GPS thing. If you could test that problem in the wifi environment,then we can see where problem regarding to internet connection issue or GPS receiver issue. From that you might easier find out the solution. Good luck.
1helpful
Can you surf the web on an Apple iPhone without a Wi-Fi connection?
There are two nation-wide cell networks that allow you to browse the internet. The EDGE network (for original iPhone) and the 3G network (3G is faster, but not as widespread and can only be accessed through the iPhone 3G ). iPhone monthly plans include unlimited use of the internet, without using up your calling minutes.
If you can take advantage of a nearby wireless hub, you'll have much better speed than when you're on a cell-phone data network... but even without wireless, you can still browse, email, work and play via the EDGE or 3G cell-phone network.
2helpful
3answers
Iphone 3G screen not working after dropping. Not
It sounds like you have some internal screen damage, your LCD may be damaged or your digitizer. A professional will need to take your phone apart and determine the cause.
8helpful
4answers
Iphone 3G Erase All content and settings problem
DFU means Device Firmware Update. If a restore using Recovery Mode doesn't work you will want to use DFU Mode as a last resort. When placing your iPhone into DFU Mode it does not load the OS before attempting the restore
videothumb.pngWatch the Video!
For your convenience this tutorial is available in video format also. Click the Watch It button to view the tutorial!
To put the iPhone into DFU mode so you can do an iTunes firmware restore follow these steps:
Step One
Open iTunes and connect the iPhone to your Mac.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone screen will remain black like this:
NOTE***: It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long!
2helpful
My Iphone 3G blutooth doesntwork and have internet problems.
the iPhone doesnt actually have the ability to send and recieve files from other phones. Its just for the headset ability. If your phone is Jailbroken you may find some programs out there that allows you to send and recieve messages and find other phones via Bluetooth. YES going on the internet without a DATA PLAN will cost you money. It depends on what carrier you are with, it will very on how much per kilobyte. You can not record videos unless you phone is jailbroken. Then you can download the ability to use the camera as a video recorder. Some of the programs are the following: Cycorder and 3G video recorder. Hope this helps!
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
