Wind it back and forth at least 15 times, then twist the watch very quickly back and forth a few times. That should restart the balance wheel moving. Twisting motion must be around the axis on which watch hands are fitted.
I have the same watch 20 years old. I cannot wind this watch.
it is self winding , which is generated by arm or wrist movement.
i purchased a box for times I won't be wearing. Will rotate watch 5 minutes every hour ( belt driven- only use that other winders say gear my experience is belt drive more reliable)
if you have to wind this watch I would question if it is real Rolex.
The Rolex time change is done after three clicks when you pull the winder. If the winder can actually be pulled out of the stem (separate) the damage is serious.
Sorry. Only an authorized dealer can get the parts for it to be repaired.
Unscrew crown pullout 2 stepsturn hands around till the date changes .this will indicate to you it is midnight .turn ands around to right time.if you are setting this in the afternoon remember to go past the 12.When this is done push winder in 1 step and turn winder clockwise or anti cclocwise and this will let you set day or date. When you finish push winder back in and lock down.
mcdevito75 here, I would imagine your Rolex is an automatic, not all Rolexes are. After 2 days not running at all your Rolex needs a very good start not just putting it on and that"s it. Sorry to say!, I would ask you to do this, With your watch close to your ear I would like you to wind the watch, listen closely, if you haer a clicking or a drag sound you know you have to give about 20 winds to your watch before you put it on, after the 20 winds the automatic takes over. If the stem just spins and no sound, Click or drag, then your rolex is fully automatic, after you put it on you"ll have to ttwist your wrist back and forth to get the automatic moveing to wind your watch somewhat. Twist your wrist back and forth maybe 20--30 times, this way your watch has an initial wind and as you wear it the winding continues with the motion of your wrist, after it"s wound pretty good if it stops and goes, have the watch serviced.
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple: 1) when you unscrew the crown, it is in winding position, 2)
when you pull out the crown to the first click, it is in day and date
setting position (depending wich way you turn the crown). NOTE: to
adjust the day or date, previously you have to advance hands forward,
passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m.
using the crown in position as described in chapter 3. When done - push
the crown fully in, then pull out to the first click and only then
adjust the day or date. 3) when you pull the crown further out to the second click, it is in time setting position. To
find the daytime or night time on the watch: pull out crown to the
second click and advance watch hands forward till you pass the 12 mark
on dial. If the date changes as you pass it - it is the night time
(midnight). If the date do not change as you pass it - it is the
daytime (noon). After all settings being done, allways screw the crown back down as it protects the watch from water and moisture. Never use watch in sauna- it's not designed for that. Do not forget to rate, please.
daytime (noon). After all settings being done, always screw the crown back down as it protects the watch from water and moisture. Never use watch in sauna- it's not designed for that. Do not forget to rate, please.
If not worn, you should wind it about 50 turns before wearing. If worn every day after, and you are active you shouldn't have to wind it again. If you wear it every once in awhile, then about 50 turns should do. What happens is people think that when they put on their automatic watch, and it starts it is going, but it needs that back-up power to run correctly and not run slow.
You need to go to a place that sells watch and jewelry supplies, because there is a certain tool for opening a Rolex. I am interested in knowing why you need to open it up though. If this is a Authentic Rolex ALL womans Rolex watches are automatics. Try unscrewing the crown (the part used to set the time ) counter clockwise and then clockwise turn the crown and listen to hear it winding, if it is infact an automatic, wind it 50 times. After winding, push crown in ( it is spring loaded) and screw in clockwise. It should run. If wearing every day you will not have to wind again, if wearing less frequently rewind as specified.
