This means that the Windows is about to crash. To save your data you must follow the links below
Crashed Windows : No Problem
Saving Data After A Crashed Windows On...
SOURCE: Windows startup error
If it is Windows Vista and it happened after a Windows Update, you might have the problem as described in Microsoft Knowledge Base article KB946084. No matter what you do (any F8 option such as Safe Mode or Command Prompt, or trying to boot from a Vista CD) you end up at the Blue Screen of Death.
Something is corrupted on the hard drive (not a hardware error) and now Vista has a fit if it sees the drive, even as a secondary or external drive (it goes to the BSOD with STOP: 0x0000C1F5).
The only solution so far is to erase the Vista partition and re-install Vista. You can take the drive and connect it to another computer running XP (using an external drive enclosure for example) to get the data off of it. Then do a format on the partition. Now reinstall the drive and you can load Vista. If you have no Vista disk but there was a Recovery Partition, this will now work.
SOURCE: computer goes to blue screen on start up that says
Sounds like it's time to run chkdsk on your system, at least that may repair the volume. See links about this stop error code here and here. For instructions to run chkdsk, see here, here, here and here or here. If you never installed the recovery console, you'll need your xp disks to run chkdsk. Here are the instructions to run the recovery console.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Control Panel Help Button
Your system's control panel provides you with information and troubleshooting help. When an error or warning condition occurs, the control panel displays a message informing you of the
problem. In many cases, the control panel also displays an animated graphic showing the
location of the problem, such as the location of a paper jam.
To view information about how to fix the problem, press the control panel's Help button,
which is labeled with a "?" symbol. You can press the Help button at any time to get additional
information about the message or menu displayed on the control panel.
PhaserSMART Technical Support
PhaserSMART Technical Support is an automated, Internet-based support system. Use your default web browser to send diagnostic information from your printer to our web site for analysis. PhaserSMART Technical Support examines the information, diagnoses the problem,
and proposes a solution. If the problem is not resolved with the solution, PhaserSMART
Technical Support assists you in opening a Service Request with Xerox Customer Support.
To access PhaserSMART Technical Support:
1. Open your browser and go to www.phaserSMART.com.
2. Enter your system's IP address in the browser window.
3. Follow the instructions on the screen.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
