SOURCE: Checking virtual IP servers... [VIP Raw]
por favor solucionen mi problema no me deja abrir mi msn dice que mi cuenta a sido bloqueada y que tengo que desbloquearla , ayudame por favor desbloqueela en codigo de desbloqueo es 81003003 ese codigo me dan para entrar ahi
SOURCE: not able to sign into messenger and receiving this
Clickthe "Messenger" menu in Yahoo! Messenger and select "ConnectionPreferences." 2.Enable the "No network detection" option and then click the"OK" button at the bottom of the window. 3.Yahoo! Messenger will ask you if you want to sign in again with your new proxysettings. Click the "OK" button. 4.Enter your Yahoo! ID and password and click the "Sign In" button. youmay have a registry problem download registry cleaner reginout to fix the issue
1) Clear your browsers out
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_ccleaner/
Open Internet Explorer (even if you use another browser as default) > Tools > Internet Options > Connections tab > LAN settings > Uncheck all the boxes and check "Automtically detect settings" > Save > Save
please do it on clarification
we need free vip
standard life vip login: input my user code and PIN
