Logitech ClearChat Stereo Headset Headset Logo
Posted on Feb 28, 2010
Using Ventrilo, I can hear my partner but they can't hear me, is there someting in the setup I am missing?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
730
Points
How to pair blackberry 8520 curve with sony wireless stereo headset bluetooth
My ventrilo is stuck at synchorizing and I uninstalled/installed
check out this link for more information on some network/firewall issues that could be causing your problem.
tip
How to back up using Ventrilo
<p>Ventrilo is an application that a web server and you can chat with other registered users. Ventrilo is often used in games will allow players in multiplayer games, real-time interaction. Some users have programmed several Ventrilo server setup on the machine. Ventrilo safe is copying a specific file on the backup device. This ensures that your server settings, copy the file, you do not recover your hard drive. <br /> <p><br /> <p>1. Click the Windows Start button. Click Open "Computer" from an Explorer window. Double-click the C drive to a list of folders on your computer to see. <br /> <p><br /> <p>2. Double-click the Documents and Settings folder. "This is a folder with the profiles and preferences of the user. Each user has a separate folder. The folder is labeled with the user. Double-click your user name in the list of folders. <br /> <p><br /> <p>3. Double click "Application Data", double click on "Ventrilo". This folder is the file "ventrilo2.ini. This includes all settings for Ventrilo. Right click on the file and choose Copy. <br /> <p><br /> <p>4. Click the Windows Start button and click My Computer. Right-click the drive where you want to copy the settings Ventrilo. This may be a CD or DVD, or you can use on an external hard disk. Click "Insert" to back up your settings in Ventrilo to create. <br />
on Jun 22, 2011 • Computers & Internet
The other day i was using my mic and it stopped working. and know i have no idea,and i went to your page and followed instructions from a post and now i can't hear anything. So the problem is that i can't...
turn up the volume first.
does it make a click noise out the speakers or show a reading on your mix etc when you switch it on.
if it doesnt then the switch could have gone,other than that i've only ever repaired 2 mics before & they both had doggie switches so i carn't really say more than that. sorry mate.
Mic not working in ventrilo after I installed new video card
You probably need to upgrade your drivers too....let us know if it works, and please be kind when ranking.
Good Luck
Cant hear but mic works
Ventrilo has an excellent forum system and I am sure you will find an answer there.
2helpful
Ventrilo static weird occurance
First, make sure your mike/headphones are plugged in all the way to the correct jack port.
Then, re-download and install vent.
Also, go to "setup" in vent, then make sure the inbound and outbound are either set higher or lower than the default.
Hope these help, and please rate ^_^
8helpful
Checking voice mail from remote location
If you are using Partner voicemail, you would just press *7 when you hear the voicemail system.
If you press *7, and do not get prompted for the extension number, you dont have a Partner voicemail.
Can hear everything except my girlfriend ):
Is it through an IM program? If so I had a simular problem and I open the sound settings and made sure non of them were muted and it worked fine after that.
Hiiiiiiiiiii
in the windows volume control un mute the microphone and also, you can get a program like ventrilo
www.ventrilo.com
its a voice chat software, use the setup to test your microphone.
2answers
Headset paired but doesnt function in ventrilo
Did you ever figure out what was wrong. Mine is doing the same with my LG shine. I will have to take it in for service. You had the problem quite awhile ago. Hoping you got an answer.
Top Logitech Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
