I have a 2002 polaris x edge 700 and it bogs down when i give it throttle, but if i let off i get power back and only after i ride it for about 5 mins.
? 6:05
https://www.youtube.com/watch?v=aEPx7OsywNk
Dec 11, 2009 - Uploaded by PolarisRich
A quick video on how to adjust your Polaris Snowmobiles Throttle ... TPS cause this? it seems like it hits top rpm, it runs flawlessup to the ... Would this work on a 2011 Polaris pro rmk 800?? ... I have a 2006 Polaris Fusion 600 h.o. It seems to bog out when u first start ... Sounds like its a carb or clutch issue!
Jan 30, 2012 - 52 posts - ‎33 authors
[Archive] 2011 Pro RMK 800 Top End Bogging Polaris: Pro-Ride. ... Sled is a 2011 ProRMK 800 155, 1700 kms, MBRP can. ... problems with bogging at every rpm and roughidle, I am running 91 from .... fuel filter yet?...almost sounds like your fuel pump can't keep up with ..... I am running a 2010 660 CFI-4.
2010 dragon 155 RMK electrical problems
Feb 3, 2013 Polaris update
100+ posts
Nov 15, 2009 ~~The Official Phazer Thread~~
100+ posts
Sep 12, 2009 M1000 Hiccups on the Bottom
100+ posts
Jan 28, 2008 More results from www.snowest.com
I literally had the same exact problem yesterday and last year. Perfect from start up to about 2 hours in...then sounds like it's bogging down, then dies at a trail stop. Fired right back up in about 2 minutes. Also it happened on a lake burn..wanted to die, so I feathered the throttle, came right back to life just as strong as it should be. It has me stumped. If you figure it out, let me know and I'll do the same. Mine is an 03 Edge 800 XC SP.
NO! Check the boot between the carb and engine. Very common problem for aged rubber is non-visual cracks. Pull it off and check the boot by kneeding it and looking at it under a light.
Sounds like you may need a valve job. Have you been keeping the valve clearances adjusted? It's important to do that on a four-stroke engine. Check your compression to find out if the valves are ok.
sounds like an overly rich condition when you let throttle snap shut no air enters or at least minamal air enters the engine and with to much gas the engine will bog down until the extra gas burns off(5 seconds) check floats height and make sure jets are secure and make sure the choke is all the way off
