Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Cannot scan to email Konica Minolta 250 Bizhub
When I add the email address on the smtp scan to email settings it says invalid value. This is after I have pinged the email server address as well!
Server email address is correct and bizhub is on nw as I can connect to it via Mozilla.
Thanks
Allan
  • 2 more comments
  • Anonymous Mar 13, 2014
    Inputing an email address so i can scan paperwork inot my computer
    This comes up when I try to scan a document to my email address.
  • Anonymous Mar 21, 2014
    How do I remove the addresses froman e-mail before forwarding ? I do not see a "CUT" icon on your E-mail page.
  • Anonymous Mar 26, 2014
    Kyocera KM-C4035 that cannot connect to the smtp server when trying to scan to email.
To scan to email, Administrator email address must be set in the machine (any bogus email address will work too).
Also, email server address must be input as IP address if DNS or WINS is not running in LAN.
Posted on Mar 09, 2008
  • Robert Coveney
    Robert Coveney May 14, 2014
    How do I find the e-mail server address?
SOURCE:
Scan to Email Configuration, Step by Step
Just set up email as normal, scan doc to pc,check docs or scan folder on pc for scanned doc, open new email and click the attach icon, navigate to scanned doc folder, highlight and press ok, then type address and send.
Feb 22, 2015 | Konica Minolta Minolta BIZHUB 3320 BRAND...
Unable to scan mail
using static or DHPC ip addressing is the proper port set up SMTP and or POP3. Mail server correctly set up.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 28, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub C252, network settings not available
go to google then in the URL box not search type in the ip address of the copier will get the copiers web page. log in as administrator theres a tab for network then select scan to email smtp info goes there
Jan 27, 2018 | Konica Minolta bizhub C250 All-In-One...
On C35 bizhun get error when scan to email SCAN TX FAILED JOB CANCELLED any help?
your email settings got messed up... you need to go to pagescope (web interface) by typing the ip address in your webbrouser that is connected to the network and check the scan settings to see if mybe you missed something or if something has changed....
Oct 07, 2011 | Konica Minolta Konica Bizhub C353 Drum...
I need to scan to email using the c353 konica Minolta. I used the same settings that the copier has that is working, but this one i set up won't scan to email.
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
Jun 12, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Oct 20, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta 250 Bizhub scanning Operations
You need to create a "one-touch"
This can be done in the Admin Screen without having to enter a code.
Better yet is to just yype the IP address into your browser and create them there.
The copier will need an email address in order to send them and you may need to log out and then back into the 250 as an "Admin".
Jul 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Cannot Scan To E-Mail
yes, you can, go to brauser and type your bizhub ip aadress, you'll get a webscope page, there log in as administrator and under network choose e-mailt - smtp and there shold be a place where you can mark, that youre smtp server requires authentication.
May 05, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub 350
use web browser, go your 350 ip address log in as admin, in network setting fill smtp server address and also you have to put email address for the printer and maybe its required to fill admin email also. and should work.
Feb 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Can not make bizhub c252 scanning trough e-mail feature
with scan to Email on this machine you need a mail server that is local with ftp scanning you need IIS running on either XP Pro or server OS SMB Scanning can be done but only if you are using an eithernet connection which one of these do you want do to do
Sep 20, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
14,190 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
