If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
ok go to menue if still you have this problem your panel is not good
but if this problem disappera then this the problem of your T-CON BOARD for falt cables that attached to T-CON board
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
The Control PWB only causes this defect when the Backlight Control Signals are Output from the Control PWB
No LVDS(Low Voltage Differential Signaling) signal may also result in this symptom
Hi, The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries. Thanks for using fixya.
I have vertical lines when watching tv or dvd.
