If your freezer is staying cold enough ( near zero degrees F.) then the cold control is bad. If it's not cold enough then you have a defrost problem.
Either the cold control thermostat is defective or the rtc overload contactor has welded itself together and cant open and close the power contacts to the unit,un plug the cold control and see if the unit stops then
