How to open Canon iP3000 and remove absorber pads? Printer Canon iP3000 displayed the message: Error 1700, waste ink absorber almost full. I've re-set it but can not find practical instruction how to open the printer, remove the contaminated ink absorber pads in order to flush them. Could anyone tell me how to open Canon iP3000 properly and remove the ink absorber pads, please? Or may be there is some website/forum where such instructions can be found? Thanks in advance! Elisabeth
Instructions tell me that the ink absorber is nearly full. How can you change it?Instructions tell me that the ink absorber is nearly full. How can you change it?
You can't post conmments that contain an email address.
You need to replace the ink absorber kit and to completely disassemble the printer to replace the absorber. Attempting to clean the ink absorber is not recommended. Self servicing the absorber can be a very messy operation. I would check with a Canon repair center to see what the cost to have the servicing done by a trained technician. In some cases, it is cheaper to replace the printer.
Hi There
Try this is for your printer, but donr forget some time you will need to clean out the waste ink pads that are inside the prinyer.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error) Solution: Press the <RESUME/CANCEL> button to clear the error (1700) Waste ink absorber error 1700 The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible. Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error) Solution: Press the <RESUME/CANCEL> button to clear the error (1700) Waste ink absorber error 1700 The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
This applies to Canon printers but since you did not specify the printer name and model here is the information I have courtesy of Canon's Support Website.
Don
Reset Printer Canon IP2000 / IP3000 By pelda 1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal.
Trying to clean my iP 3000, How and where do I start.
I have the same problem with my ip3000. I s there anyway to get to the waste ink absorber to clean it?
On Canon MX870 printer where to find that ink absorber
where to find that ink absorber tank in a canon mx870 printer
where to find the ink absorber in a canon mx870 printer
canon mx340 replace waste ink absorber pad
