SOURCE: Need help setting up Lionel North Pole Central
I had the same dilema and trains are not new to me. Look under the piece of straight track that has a notch in it for the wiring. There will be a clip to hold the wire and a piece of plactic that looks like a block. One either side of that is a metal tab that one end of the wiring slides over. Actually each piece of the Fastrack has one of these. Only one has a notch but you can notch any one.
MHC
SOURCE: I have two vintage Lionel ZW Transformers and both
The green light on the right side is a power light, and is on whenever there is AC power connected to the cord. The red light on the left is a short circuit indicator, and comes on when the center rail is grounded to the outside rail by any number of reasons, usually a derailed car, or wiring problem. Check photos on ebay to see what the red and green lenses look like of they are missing. There is a 40-50 year old circuit breaker that should pop during a short circuit, if the breaker is still working properly. If you want to test it, just lay a screwdriver between the center and outside rails until the left light comes on, but don't let it go too long, it could get hot and cause a fire. If it does not pop, you need to get it serviced.
Testimonial: "Simple problem solved by some one in the know! Thanks.....Carl"
SOURCE: Ι've just joined 2 ovals
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
SOURCE: No longer have manual for
See link below to PDF file with instructions to your transformer. It looks like you are correct with regards to the wiring with what I can see in the manual.
Hope this helps and good luck
www.lionellines.com/files/manuals/KW_Manual.pdf
