Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
I have a sony trinitron kv36hs500 tv which power problems
I have a sony trinitron kv36hs500 tv which power on sometimes and has to wait for day or two for it to work again. the problem is getting worse.
    Problem Solver:
  • 10 Answers
Try making resolders on power supply ckts, try also adjust screen voltage,, check crt socket,,if all of this dont solve it, try to rejuvinate the crt.
Posted on Feb 27, 2010
SOURCE:
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
There is no picture or sound and the stand by/timer light is flashing on the television.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV36HS500
http://www.givemefile.net/smanuals/tv/sony/file/7973.html
Above Sony support, below is a service and repair manual This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Akai, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
May 13, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony kv36hs500 does it have a focus ajustment? i had the high voltage chip replaced t v doing fine just not as clear as it was.
Yes, It has focus control at side of fly-back transformer. Rotate focus control in both sides to get maximum sharp focus.
Feb 19, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sonn tv
There is a very common problem in yur set that will cause this. The KV36hs500 is knowen for two IC's to cause intermitant power condition. A good repair shop will run you somewhere between $300-$400 to do the repair.
Oct 28, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony KV36HS500 won't turn on
3 times blinks shows problem of failure of IC6505 in DZ board. If you know basic electronics, open the back cover of tv and go ahead.
Jul 20, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony KV36HS500 Flyback Shorts
I HAVE A SONY CRT TV, BUT THE TUBE IS BROKEN. i BELIEVED. THE TV IS
Sony KV36HS500
May 23, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony KV Trinitron WEGA 36" TV won't turn on
My 36 wega did the same thing last week it must be contagious. Blinks 7 times mostly but sometimes 6 if hit power switch again. The problem is the D-boards shorted Flyback high voltage transformer but the ones Sony is selling $130 do not hold up and seem to burn out in a few days, yes twice bitten. Finally they send me new D-board can't wait to see if this fixes it once and for all. The board costs around $200 but is worth it to get it running again.
May 02, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
225 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
