Problem started today, drove to hardware store three blocks away and when I came out car would not start. I walked home came back an hour later to tow it home car started. Drove home and then went to Auto store
Put it on diagnostic tool and the following codes came up P0340and CodeP0335
Crank shaft position sensor
probable causes
Crank shaft defective, Check connector and wiring to sensor, or check trigger wheel for damage
Code P0340 reads Cam Shaft sensor
Cam shaft sensor defective, Check sensor and wiring to sensor Engine mechanical condition timing belt/chain not in time
Can anyone tell me where approiximately where these parts the Crank Shaft is located and the Cam shaft is located so I can replace them if needed?
Thank you
Mcdevito75 here, BEST BET, let the shop do this work, too many un forseen problems could come up. The stalling and unable to start for a while could also be a bad ignition module, no test for this part, but I would have it changed, for if it is a bad ignition module, all this other work will not fix the stalling and later start of your car.
