Have you remove the motor shroud? unplug unit first, you should be able to see a 15 amp ceramic fuse ( white colored) if you have a multi-meter check continuity if open replace it and if it blows the fuse again then the motor control board has a direct short to ground and the board will need to be replaced. Just wondering has this unit ever been serviced or any maintenance done on it? if not! suggest you do so.
