This is unfortunately a known issue with the Pearl. There are a couple
reasons to why this happens. If your battery is defective, then your
phone will sporadically believe that your phone is low on battery (even
when its not), this will cause your phone to kick the radio off by
itself--even every 5 minutes. Try cleaning the battery contacts or even
try a new battery. Another reason is a faulty OS, if the battery
replacement doesn't work, then the problem is with your OS and will have
to be re-installed. I know this sounds like a hassle, but its a known
issue and it should take care of your problems.
When there is no signal around ur blackberry will shut off the radio instead of constantly searching for one which really kills battery power just make sure you arent in a real signal dead area and you should be fine to turn it back on just go to manage connections and click it back on,if this is not the problem then there might be some problem with ur phone.
Try taking battery out and putting it back in - have had a couple of problems with my own blackberry and this is advice I was given, and it worked! Might be worth a try anyway.
If it was spotty reception, I'd suggest the antenna may have been damaged when dropped. They do get damaged.
But systemic, timed 16 second bursts?
In Settings, when is your phone configured to 'go to sleep'? After how long a period of inactivity?
It may not be considering the radio signal is be sufficient activity to justify keeping it 'awake'.
my phone wont stay on and when it does come back on it shuts right back off. the LED light on the front keeps flashing red. ive taken the battery out and everything and nothing seems to work. help please!
There might be some issue with the BlackBerry Device Software associated with the BlackBerry smartphone so Upgrade the BlackBerry smartphone with a newer version of BlackBerry Device Software and make sure that you have taken a backup before upgrading.
You can always try and reprovision your phone and resend the Host Routing Table (HRT) but if it is constantly dropping service it is probably a hardware issue and not something that can be permanently fixed. It could also be a radio issue but I would take it back and request a new one.
