I have a 12 in Ryobi drill press. when using a microplane bit to shape wood for carving the entire chuck mechanism will fall out, what am I doing wrong?
16 speed should have a Morse taper
for the std drill chuck
to fit a different chuck the morse taper needs to be emery sanded
and the replacement chuck should stick
after using the wood block pressure press method
if not you need a new morse taper for that spindle chuck
hint
i had my drill accuracy and off center spin tolerance down to one thou
with stretched old belts I got more speeds than 16
for special jobs
my 16 speed used a morse taper two for the drill chuck
grab the bottom part of the spinning part of the drill nearest the drill's motor.
then
grab the spinning shaft bit nearest the drill bit
pull them apart slightly
when the two parts are pushed together thay lock the chuck
I own a ryobi hammer drill that does the same thing
If you go to this URL you will see a screw that is #1 in the exploded view.
http://www.ereplacementparts.com/ryobi-p206-18v-2speed-drilldriver-parts-c-7931_8051_8064.html
If the chuck on your drill is open you might be able to access this screw.
It appears that this screw holds the chuck onto the drill and removing it might allow you to remove and then replace the chuck.
I am not 100% sure of this, but it looks like a good place to start.
No there isnt. the chuck has a taper fit and needs to be cleaned and installed correctly. Use something like a brake clean or carb cleaner and spray the shaft and the internal socket of the chuck, wipe both clean with a paper towel and then move the table out of the way and with the chuck jaws fully retracted use a piece of wood and "seat the chuck" I usually strike the wood a couple of times. this should work as long as the tapers are not that worn.
Abrupt stops can loosen the ratcheting chucks. Before the invention of those chucks we had the ones that required a key. The proper way to tighten them is to alternate between all three position in order to "seat" the jaws on the bit evenly.That all but guaranteed it would not come loose I assume you have a ratcheting "one handed chuck". ther's only one way to tighten them and you don't get the same grabbing force. The only thing I can suggest is to try to eliminate abrupt stops or try cranking it tighter.
Round bits are not compatible with the Ryobi impact drivers. You need the hex shank "quick connect" bits and accessories. There is an adapter available. it is basically a regular style of keyless drill chuck with the quick connect hex shank that should fit right in to your Impact.
