Canon LaserBase MF5630 All-In-One Printer Logo
Posted on Feb 27, 2010
Osx driver not found mf5630
I can't find a driver to use my canon MF5630 on a mac with osx
tanks
george
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
472
Points
My pc currently using window7.....but my mf5630 cannot support window7.....how i can soft this problems?
Canon laserbase mf5630 windows 7 64 bit vitual pc
You can find the solution here: http://www.fixya.com/support/t11518807-looking_driver_mf5630_canon_win_64
2helpful
3answers
Looking for driver MF5630 canon Win_64
I have spent hours to find a solution... there is no driver. But there are definitely 2 solutions:
1. MF5630 - using ONLY printer in Win 7 x64:
You have to use the drivers for MF5700 Series - http://driverscollection.com/?file_cid=4213082682609f383f81540957d
- http://www.techulator.com/resources/4156-How-add-Printer-manually-your-Windows.aspx
1. First, Click on the Start button in your screen, further click on Control Panel button and then double click on Devices and Printers button.
2. Then click on Add a Printer button in the menu.
3. Further select the Add a local printer button from the available menu.
4. Then choose an existing LPT port and click Next button .
5. Further select the correct driver from the driver list menu for your printer. Suppose if the requisite driver is not available then click on the Windows Update button. After the Windows 7 Update installation finishes in your computer, once again search for the appropriate driver for your printer.
2. FINAL SOLUTION - for printer and scanner - if you have proper PC configuration:)
Win7 has a possibility: http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
you can install the WIN XP environment where you can easily install driver for Canon MF 5630 (or any other by Win7 x64 not supported printer/scanner) and additional software.
BUT YOU NEED to run: Windows 7 Professional, Enterprise, or Ultimate editions. Windows XP Mode is not supported on Windows 8.
Your BIOS must support Virtual Machine.
My mf5630 laserbase printer displays error massage Check printer cover after powering on.
your printer cover/lid may not be closed properly.
Try removing whatever removable parts present in your printer, like lid, paper tray, etc and replace them back to proper position and switch on your printer.
Most of the times, problem may get solved in this way.
I hope this might help you.
Thanks
1helpful
Since upgrading to Mac OSX Leopard the scanner does not work, how can i fix this?
For Mac OSX 10.6, there are very few Twain drivers built in.
You have to download the Twain drivers compatible with Mac 10.6, installing previous versions of the Twain drivers can cause repercussions for the Mac.
Canon should have updated drivers on their website.
3answers
I no longer have my installation CD for my cannon laser base MF5630
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
You can download the required installation drivers from manufacturer's site by clicking this www.cannon.com
Select and download the drivers according to the operating system of you computer (Win XP/Vista,others...)
2answers
Can't install my printer
The best site for downloading a software for your printer is the website of your printer brand name. Probably, www.canon.com
Don't forget to rate me..:-) Thanks..
3helpful
2answers
I have lost the installation cd for my printer how can i install it now
you can download a copy of driver for your printer from here
Click here to Download
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
1helpful
2answers
Canon mf5630 printer where is the on/off button please
The Energy Saver button serves as the ON/OFF button for the printer. It is located on the upper right corner of your dashboard. Please see image below.
IR C320N scaning with MAC OSX
Use the Irc 3200 drivers on the Canon USA
Color imageRUNNER C3200 : Drivers & Downloads
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2269&modelid=8927
old marine
old marine
ZJ Limited
ZJ Limited
