I BOUGHT A USED KENWOOD (KDC319 (Y22-9150-15) NO.20914126 MADE IN MALAYSIA) FROM RT. 60 AUTO SALVAGE NEW LONDON OHIO, I INSTALLED IT IN MY 98 GALANT USING ITS ORIGINAL PLUG THROUGH AN ADAPTER INTO THE CARS ORIGINAL SYSTEM...IT POWERS UP NORMALLY FOR APROX 2-3 SECONDS THEN THE WORDS ''CODE OFF'' APPEARS AND IT POWERS DOWN???? WILDWEST319
SOURCE: radio code
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
SOURCE: Kenwood KDC-MP825 car stereo problem
My wife experienced the same problem this month, December 2008, after owning the KDC-MP825 for 3.5 years (what's up with that?). It would power on briefly, the panel would move, then after 2 seconds it would shut down. After 15 seconds, it would power again, panel motors whir, then shut down. It would keep doing that while the key is in ignition.
This appeared to have solved the problem:
Hold down BUTTON [5], press the RESET button (you'll need a ballpen to press between the AUTO and SCRL button).
This was the procedure for getting the receiver out of demonstration mode. Maybe the cold weather here in New Jersey placed the unit into demo mode?
SOURCE: Need to reset the code on my Kenwood deck.
you should try the defaults 0000,0123,1234. in most cases unless you or the original owner put in the security code. Worse case it will just keep turning off till you get it right.
SOURCE: i lost the wiring color codes for my kenwood KDC-MP628 CDReciever
http://www.tehnomagazin.com/Auto-radio-car-connector/KENWOOD-Car-Radio-Wiring-Connector.htm for the deck
1) Remove the ashtray and the two outermost screws exposed in the ashtray cavity.
2) Remove two screws from each side of the dash console.
3) Remove the climate control knobs.
4) Unclip the trim bezel and remove.
5) Remove four screws securing the car stereo to the dash.
6) Pull car stereo from console releasing antenna and connectors.
Constant 12V+
Red
Switched 12V+
Orange/Yellow
Ground
Black
Illumination
Red/Green
Dimmer
Green/Red
Antenna
Driver's Pillar
Front Speakers
6 1/2" Doors
Left Front (+)
Orange
Left Front (-)
Black
Right Front (+)
Gray
Right Front (-)
Green
Rear Speakers
4" Tail Gate
Left Rear (+)
White
Left Rear (-)
Red
Right Rear (+)
Yellow
Right Rear (-)
Blue
SOURCE: Need Unlock Code for Kenwood MP235 car stereo
Look for a really small hole in the face plate. Put a tip of a pen into it. Press it in and then it should turn on. If this doesn't work, take it to a place that installs them, they'll help....Usually for free....
