Whirlpool LER6636PW Electric Dryer Logo
Posted on Feb 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer will not turn on?
Dryer was running. Stopped it to check clothes tried to start it again, but did not turn back on!
Anonymous
Level 3:
  • Master 10,319 Answers
  • Posted on Feb 27, 2010
Anonymous
Master
Level 3:
Answers
10319
Questions
5
Helped
3075376
Points
30576
The heat sensor maybe bad or the timer has burnt out
you will need to have it checked out
Clothes dryer does not work when power turned on at wall. Sounder goes continuously, no lights on panel and panel buttons do nothing
If it didn't do that before removing the capacitor & wires then I would assume it is something you have done wrong. Maybe put a wire back in wrong place. There is a wiring diagram on back of dryer. Motor not starting could be the capacitor, you really need to test it with a capacitor tester. It may also be the motor bearings seizing up. If motor is tight to turn when belt is off then it will be time for a new dryer. Too expensive to replace the motor on such an old dryer.
Was drying cloths yesterday and restarted it due to the cloths not being dry set it on the hottest setting, went outside and came back in and dryer was stopped...checked the breaker switch, thought it may...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dryer was making strange noise when drying clothes. stopped the dryer and removed the clothes. dryer would not start again, never had any problems before.
heatman101
Aug 02, 2011 • Dryers
My dryer is a whirlpool electric dryer that was brand new in 1998. The dryer was on, working fine...suddenly it just stopped. It was making a clicking noise. It refused to cut back on when I pushed the...
heatman101
I dried one load and the clothes seemed to be a little damp but try enough, when my daughter put clothes in it and pressed the button, it made a humming sound and did not want to turn, I waited a while and...
when it hums and won't start that's usually the motor,when was the last time you took the dryer apart and cleaned it?alot of people don't know that the dryer should be unplugged,taken apart and cleaned out,the vent line too,i bet if you open it up your motor is covered in lint,if the vent line is a long run you can remove it from the back of dryer and stick a leaf blower in it and blow it out to the outside,if it hasn't been done in a long time after you blow it run the dryer on air fluff and go outside and check to make sure the air is blowing out,sometimes blowing it could push all the lint up to the opening and block it,if it does you have to pull it out or get a brush and stick it into the pipe and clean the opening out,but you could have something stuck in the blower wheel if the dryer was started with clothes in it without the lint filter in it and a piece of clothing went down into the blower wheel stopping the motor from turning or the motor is bad,the dryer should be cleaned out at least once a year.
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
3helpful
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
2helpful
Dryer stopped working mid-cycle.
I presume she pushed the start button again. Can you hear the motor running? If so, it's a broken belt. The door switch can fail anytime. If the dryer started ok later, the motor was overheated. Lighter loads will avoid a lot of problems, and the dryer will probably work better.
Apr 21, 2009 • Dryers
Dryer stopped before clothes were dry and now it will not start again
possible bad thermal fuse remove back look for small white object on left side just above blower on side if lint screen housing with continuity checker ck to make sure there a closed connection through fuse
Dryer quit working
I have a Magic Chef Clothes dryer. Model #YE224LV. Was drying clothes, went back to ckeck and dryer wasn't running. Push botton and nothing. Check circuit breaker everything ok. What do I need to check and how. Just won't start.
Thank you!!!
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
