GE WBSR3140DW Top Load Washer Logo
Posted on Feb 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove agitator from GE washer? Model WHDRR418G1WW.
GE washer will not agitate.
Drains OK. How do I remove the agitator to see if it is still connected to clutch/motor? Thanks...Dave
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
4234
Points
How to remove agitator from GE hydrowave washer machine?
Anonymous
Level 3:
President:
  • Master 3,085 Answers
  • Posted on Mar 03, 2010
Anonymous
Master
Level 3:
President:
Answers
3085
Questions
Helped
1006480
Points
9738
Pull up and remove the softener cup
Remove the white cap
Unscrew the bolt
Pull up on the agitator to remove
  • Anonymous Aug 21, 2011
    how do you remove the white cap?
geapptech
Level 2:
Habit-Forming:
  • Expert 157 Answers
geapptech
Expert
Level 2:
Habit-Forming:
Answers
157
Questions
0
Helped
56329
Points
343
The agitator should just pull straight up and out of machine.
GE washer model #WHDRR418G1WW doesn't spin or agitate
If you can reach the wires on the switch you can temporarily unplug the wires and tape them together.
3helpful
GE WASHER #WHDRR418G1WW DRAINS BUT WON'T AGITATE OR SPIN
Most likely you'll need a new motor, you can check the belt, to see if its attached around the big pulley. To access, you'll need to pop the front cover off the unit, it has two tabs you push in, on the front, where the top lid meets the front cover. Use a flat-head, be careful not to scratch your paint.
You can also, take off your back panel, on the control console, and remove the wiring diagram, you can diagnose this washer yourself, because the motor has a blinking light that will indicate to you, what is going on with your unit, it will tell the problem for you.
Please take a look at this website, about half-way down, as it could also be your lidswitch.
http://www.appliance-repair-it.com/GE-washer-repair.html
I have a GE washer with a model number WHDRR418G1WW I think it is hard to read. Anyway, I will not agitate. I have unplugged the machine and let it sit for a minute or two and then did the reset thing but...
Try moving the agitator by hand, when turned backwards it shoud stop.
If not, romove the softener cup by pulling up, remove the cap underneath, remove the bolt, pull the top half of the agitator off, you should see broken plastic pieces.
They are called DOGS, cheap and easy to replace.
Ask your friendly appliance parts guy.
1helpful
I own a ge hydro washer. It won't spin or agitate
If you hear the motor go through the stages, but nothing is happening in the tub, the motor belt may be broken or off.
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
WHDRR418G1WW WASHER WON'T AGITATE OR SPIN, NOT MAKING NOISES. FILLS AND DRAINS FINE.
sounds like you have a broken lid switch on the washer, maybe someone slammed the door or placed or stood on top of the washer, a broken lid switch won't allow washer to go into spin mode is a safety device so if is on spin cycle an someone sticks their hand it the machine stops an not breaks your hand.
broken lid swtich
good luck leave some feedback thanks!
10helpful
2answers
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
1helpful
coupling between motor and drive assy broken. take motor loose and you can get it out. Visual check first to see if motor is running when in agitate cycle.
4helpful
The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
I just had a new GE washer delivered to my home today, June 24, 2008. All it will do is fill with water and than drain. The agitator cycle does not work and the spin cycle does not work. Model...
We had the same problem with our new GE washer.......the repairman just left. It's the circuit board on the motor that failed, causing the motor to stop working. GE will replace it under warranty.
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
