Question about RCA DRC8335
Tape stuck The vhs tape is stuck inside and the system tells me that there is no tape,
  • Anonymous Mar 12, 2008
    VHS tape stuck; take up reel has no tension on it
    found by dissassembly, might be under warrent but
    do not want to part with the tape while it is returned
    to be serviced, how to release tape from machiene
    without complete dissassembly is my problem.
    OVERALL this deck is problematic; has to be
    reset often from lockup or lack of tuning in channels
    has to have power disconnected to recycle internal
    computer glitching out I suspect, inherant to the model/
    software. Not the 1st DTV tuner/deck I have heard of this
    happening too. HOW TO GET TAPE transport to manually
    release tape ANYBODY?
  • 85 Answers
Hi, , the sensor of your unit was broke,,, or the mech is stuck,,, if you know how to dis assemble ,,, just check the mech.system first. , , , , and the rubber belt lower tape head part.. . if problem accur.. .. go to your nearest repairman
Posted on Mar 03, 2008
SOURCE:
How to remove a cassette stocked in a vhs machine?
If the VHS tape is stuck inside, and when you push the eject button, it wont come out. Then you need to unplug the VHS player, take it apart so that you can access the inside. See how the tape is stuck inside and start to take it out the best you can. Once you get it out you may have to throw away the tape if it is messed up badly, if not wind it back up. Put the VHS player back together once you get the tape out. Then try to play another VHS tape and see if it works again. If not, it may be a bad VHS player or it may be the tapes. Hope this helps. I have had to take mine apart to take a tape out, so that's how I know
Feb 12, 2015 | Televison & Video
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Tape seems to be stuck to itself, I can't free it up
I think you are refering to the tape itself in the VHS cassette and it not being stuck inside the Video itself!
So if you are... don't use the spray... video cassettes have a brake system inside them. It sometimes breaks. If you turn the cassette upside down so you can see the white reels, inbetween them near the bottom (where the side label goes) you will see a small hole. If you put a pen inside it should release the reels so you can turn them with your finger. If they don't turn it may be broken. In which case... Get hold of a blank tape, the same length as yours. Carefully remove the screws (5) on the bottom. See how it's put together. Once you understand how the tape moves etc. Take out the reels with the tape, then dismantle your video and put the reels with the old tape into the new holder. It should work as good as new.
PS try not to touch with fingers the tape.
Sep 27, 2009 | Panasonic AG-1330 VHS VCR
A VHS tape is stuck in my player. How do I get it out?
the tape might have stuck inside.. you need to open it and remove it on your own.. if you think its risky go to any nearby shop of electronics.. they will do it for few bucks..
Jul 10, 2009 | Zenith Televison & Video
VHS tape got stuuuuuuck inside the VCR
You might be able to retrive it by opening it up. This might void your warranty. Also, maybe you could just buy a new one.
May 03, 2009 | Televison & Video
Tape stuck in vhs players
Yes you can cut the tape, remove it and then go to radio shack or walmart electronics dept and get some special vhs repair tape.
Apr 27, 2009 | Sony SLV-D300P DVD Player/VCR
VHS carriage stuck
THERE IS A SENSOR SWITCH THAT TELLS THE MACHINE THE TAPE IS LOADED ... SOUNDS LIKE IT IS STUCK. PROBLEM IS ACCESS WITH COMBO'S. THEY ARE A PAIN TO GET AT. THE WHOLE BACK COVER TO THE TV MOST OF THE TIME HAS TO BE REMOVED,... I KNOW ITS NOT MUCH HELP BUT THE MANUFACTURES KNOW THAT... HOPE YOU CAN GET TO THE TRAY INSIDE. Joe_Rex
May 01, 2007 | Sylvania SRCD227 27 in. TV/DVD Combo
RCA DRC8335 Logo
289 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
