The screen is black when i try to take pictures, it still takes pictures there is a photo playback screen so i can see the pictures after they are taken and also the movie screen works, but i have to use the viewfinder to take pictures cause the screen is black when it is on auto or camera mode
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
A lot of cameras seem to be having this issue (including myself). Eventually it got to a point where the camera doesn't even turn on properly anymore. Better take it back for repair, STAT before it ends up like mine :(
try to take a picture even when you do not see anything on its screen. If the picture taken shows up afterwards, you will just need to adjust the brightness for the LCD.
it would appear that the lcd screen has malfunctioned and would need repair.... you can try power cycle by taking batteries out and press and hold power button down for 10 secs, draining all power out of camera, then put the batteries back in and try again
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank: • Camera is off. • Batteries are not correctly inserted or battery-chamber cover is not properly latched. • Batteries are exhausted. • EH-62B AC adapter (available separately) is not properly connected. • Camera is in sleep mode. Press shutter-release button halfway. • Monitor is off. • USB cable is connected. • AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode. • Batteries are exhausted. • Red (!) lamp flickers: flash is charging. • Green (AF) lamp flickers: camera unable to focus. • Message "CARD IS NOT FORMATTED" appears in monitor: memory card is not formatted for use in your camera. • Message "OUT OF MEMORY" appears in monitor: insufficient memory to record picture at current Image mode setting.
did you fully charge the battery before use when you bought the camera? and is it charged now?
most cameras can take photos but not be able to hook up to download. because photos take less energy it may be that it has just enough energy to take a picture, but not quite enough to do anything else.
i don't think your stupid, its just that some people don't think of the little things as be possible.
also could check to see if there is any obstructions. (dirt, little pieces of plastic, etc.) on the main routing items. (memory card, plug-both ends, inside the camera housing itself).
hope i could help
GOOD LUCK!
