Follow this link and contact Bulova: http://www.bulova.com/contact/contact.aspx Rate me, please.
I called Bulova's service and repair dept., and they are sending me 2 links for free! 1-800-233-3350
SOURCE: Armitron watch band needs extra links
I just called the main headquarters and they sent me 2 links for FREE!!! 1-800-840-2933 my model # for my watch is 20/1897T1 found on back. Hope this helps :)
SOURCE: Need to add a link to Armatron watch band
You have to call Armitron to get extra links for this watch. You could add them in yourself (if you purchase a watch link remover tool), or you could take it to a jeweler. You could also ask if they have the easy links which just snap on and off available when you call and these can be just snapped on and off without any tools.
SOURCE: how do I remove extra
there shoulf be screws on the side of the watch to remove. If not they will queeze together and pop out and you will need a tool to do this with. So basically if that the case you need to take it to a dealer or shop and have them remove it. Thats the case with some high end watches.
SOURCE: how do I take out links to size my bulova tfx
You have to press the pin out of the side of the ban. I use a tool they sell at harbor freight tools to do it. If you dont have a harbor freight near you they have an online store. You can also use a good push pin and a small hammer to tap the pin out. Put the ban on it's side over a small hole drilled i a flat piece of wood so the pin can come out without bending. do this for each link you want out then tap the pin back in on the last link to put it back togather. Sometimes there is an arrow on the inside of the ban showing you the direction to drive the pin out
SOURCE: Need extra link for an Anne Klein 10-7977MPTT watch
I called Anne Klein saying I wanted to purchase additional links for an Anne Klein watch I had purchased, and I was (very kindly) instructed to call the following number between 8am and 5pm EST: 1-800-937-0050 ext. 203. I'll be calling tomorrow. Good luck!
