Kodak ESP9 All-in-One w/USB Cable & 4x6 Premium Paper InkJet Printer Logo
Anonymous Posted on Feb 26, 2010
Kodak ESP 7 WIFI problems
I have a Kodak ESP 7 AiO printer that worked flawlessly with my WIFI (wireless) network running a D-Link wireless router. I have since switched to Qwest and got an Actiontec PK5000 wireless router. When I enter the network info on the Kodak ESP 7 it says it is connected and I can even view the flash memory on all computers on the network. I have let Bonjour and all Kodak programs through every firewall on every computer. I've tried both Dynamic and Automatic IP Addresses, as well as even set it up for static IP. All firmware and software upgrades are current. Still no luck! I've contacted Kodak about this and they seem to just give me the run around of the same old basic things to try that the FAQ or troubleshooting states to do. All computers are running Windows 7 and the only way I can get it to connect or recognized is by hooking it up via USB to my desktop. Maybe this is a bug with the Kodak software, Windows 7, or maybe even the router??? Any Suggestions Appreciated!
Anonymous
Level 2:
New Friend:
  • Expert 103 Answers
  • Posted on Mar 01, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
103
Questions
0
Helped
50463
Points
160
The ACTIONTEC GT124, M1000 and PK5000 Routers are not compatible with wireless-enabled all-in-one printers. These routers cannot connect to your all-in-one printer because they do not support the multicast protocol. Contact your router supplier for additional assistance and to determine if your router will be able to support the muticast protocol in the future.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6121
Points
Today I contacted Kodak about my ESP5250 wireless printer and they said it won't work with the Actiontec PK-5000 because it does not multicast. My old Actiontec wt-701-wg worked fine, but qwest couldn't find any other answer for me for my problems with intermittent stalling of my browser, so they told me my 5 year old modem was too old and to buy a new pk-5000. Same problems. Tonight I contacted qwest to tell them about this problem and they said it is now a known problem, and recommended an actiontec Q1000. Hope they tell the girls in the Phillipines this. Hope this helps.
Jerry
Anonymous
Level 1:
New Friend:
  • Posted on May 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6121
Points
YES I HAVE THE SAME CONNECTION PROBLEMS WITH THE PK 5000 I ALSO HAVE THE KODAK 5250 WIRELESS PRINTER I HAVE BEEN TO INDIA FOR HOURS, (KODAK SITE, ''FOUR TIMES) THEY RECONNECT ME TO MY PRINTER, THEN SHORTLY AFTER, ''KERPLUNK'' I CONNTACTED QWEST, AND THEY SAID A Q1000 SHOULD WORK? I'M DOUBTFUL, RELUCTANT TO CONNECT THE Q1000 HAS ANYONE HAD BETTER RESULTS WITH ANOTHER WIRELESS ROUTER BRAND?? IF SO PLEASE HELP THANKS, ED.
  • Anonymous May 15, 2010
    Hello again, this is [email protected]. I'm still in aquandary re, my ability to remain connected to my wireless printer. As I have stated before, my wireless printer is a Kodak 5250, and my router hookup is the PK5000 Qwest has sent me a Q1000 router that they say ''should'' work. I'm still reluctant to hook it up(all the hoopla that goes with it). The primary reason is, that Kodak says I will have better results either with the Netgear or Linksys router. Anyone with any knowledge or help with this dilemma would be ''most appreciated. I have been told this is an ongoing problem?? , Thanks
How do I connect to WiFi on kodak esp 7250 printer?
First turn on the wireless network on your printer. then searched your WIFI SSID input Password if necessary.
How to connect kodak ESP 1.2 printer to sky netgear router dg934g
The ESP printers won't work wirelessly. This is a limitation of Kodak. Do yourself a favor and get a laser printer with a network card. Best decision I ever made to scrap the Kodak. It was always running out of ink in a week or two, even if I didn't print anything anyway...
I have a Kodak ESP5210. Its an all-in-one with the printer, copier, and scanner. I can't get my scanner to work. I put a picture on it and hit "Start" and all it did was keep saying scanning. It...
Make sure any other scanners are disconnected from your computer. I had a problem with the scanner in the Kodak ESP 7 AIO printer. Kodak advised me to disconnect my other scanner. After I disconnected my Canon scanner, I was able to use the Kodak ESP 7 scanner.
MWR
3helpful
2answers
Toshiba laptop running Vista won't connect to Kodak ESP7 Printer
Connecting Kodak ESP 5250 Printer to Windows Vista PC through Wireless Network.
After following the initial steps in the Start Here booklet that comes with the printer (unpacking, connecting power, inserting print-head/ink-cartridges and calibrating) I connected the printer to my computer through the USB cable as per page 7 of the booklet because I needed to get started printing quickly. Two notes: the USB cable supplied was pretty short and wouldn't work with an extender-I'm not sure why-so I used an older, longer one I had. And as with most printers, do NOT connect the USB cable right away. Start the software installation first and only connect when it tells you to. I downloaded the latest version of the printer software from Kodak, but I don't it made much difference and it was a very large download.
To go wireless the first thing you need to do is get the printer onto your network. Do this by turning the printer on and pressing the Menu button. On the printer's LCD screen cursor down to and select Network Settings then WiFi Setup Wizard. At this point you need to have some familiarity with your wireless router and the security routine(s) you are using. Pages 8 and 9 of the Start Here booklet walks you through these steps. I don't used data encryption (probably should, but too lazy and also wonder if it will reduce transmission speed), but I do use MAC filtering to keep unknown devices (like my neighbor's computers) off my network. The booklet does not address this. If you are not using data encryption (I think WPA-2 is current the standard) you should at least use MAC filtering. If you use data encryption you don't really need MAC filtering, but some folks use both. MAC filtering works like this. Every wireless device has a unique MAC address that is put in when manufactured. It is permanent and not shared with any other device in the world. If you turn MAC filtering on in your router configuration, then you must enter into your router a list of all devices that you want the router to allow onto the network. Anything that is not on the list will not be allowed on. This gives you absolute control over who/what gets on your network. But unless you also use data encryption, the data transmitted between your computer and your router could possibly be picked up and viewed by others. This would require some pretty special equipment, not something your neighbors could do with their home computers, but it does exist. The other thing is, with some devices it is a bit of a struggle to find the MAC address. I had a hard time with my netbook that uses a UNIX operating system, but finally got it. If you are using MAC filtering you can find the printer's MAC address by going to Network Settings then View Network Configuration and scrolling down to the bottom. Anyway, once your printer is truly connected to your router you should see a blue WiFi indicator at the bottom right of the printer's main screen (the one with "Kodak" in red letters in the top half of the screen). If you are still in the menu screens you can go to the main screen by pressing the Cancel button on the printer.
Connecting the printer was the easy part. Getting the computer to talk to it is not so easy. If you connected by USB first, unplug the USB cable. If you were connected by USB you already have the software installed. If not, now's the time, either by disk that came with the printer or by download from the Kodak Help Center (just search this term). Be advised, the download is large and takes some time. The software will install the Kodak AiO Home Center on your computer. After you install it, it will be found in the Kodak folder on the Start Menu. No indication is given, but at the same time AiO is installed the Bonjour Printer Wizard is also installed in a separate Bonjour folder on the Start Menu. More on this in a minute. If by some strange quirk of fate your printer will now accept documents from your computer through your network that's great. Mine didn't so I finally called Kodak's printer support number and after a very short wait (good on you, Kodak!) I got the following help. The first part was to make sure my computer and printer could talk to each other through my wireless network. This was done by "pinging" the printer from the computer. You will need the printer's IP address which can be found under View Network Settings (see above). It consists of 4 numbers separated by periods. The numbers can have anything from one to three digits each. Once you have the IP address available, click on the Start button at the bottom left of the Windows screen. Then click on All Programs. Open the Accessories folder and start the Command Prompt. This should open a box with a black background with a command line ending in "
Cannot install Kodak AiO ESP 5 printer in Windows 7
Kindly call 1800 421 6699 and ask for a supervisor straight away.The representatives can connect you to supervisor after taking your informations.The supervisors can remotely access your computer and get the software installed on your computer.
Got aio kodak 5500 printer hw to print wirelessly,
The Kodak 5500 AiO Printer has no WiFi functionality and thus will not work wirelessly
1helpful
2answers
Battling between KODAK AIO 7 vs Dell wireless laptop.
try this
  1. Open the Printers folder:
  2. XP Operating System: Select Start > Settings > Printers and Faxes.
  • VISTA Operating System: Select Start > Control Panel > Printers.
  1. Delete all ESP 7 and ESP 9 printers from the folder. The printers are listed as "KodakESP7+xxxx" or "KodakESP9+xxxx", where xxxx can be any number.
  2. Close the Printers folder.
  3. Press Ctrl + Alt + Delete on your computer keyboard, then select Task Manager.
  4. Select the Processes tab.
  5. Stop each of the following processes. For each process, click the process, then click End Process.
  6. AiOHomeCenter.exe
  • EasyShare.exe
  • EKDiscovery.exe
  • EKIJ5000MUI.exe
  • KodakSvc.exe
  • mDNSResponder.exe
  1. Power cycle the printer. (Press the power button to turn off the printer. Wait approximately 30 seconds, then press the power button to turn on the printer.)
  2. Open the home center software.
  3. Click Install Kodak Printer in the bottom right corner of the home center to add your all-in-one printer to your computer.
let me know if this worked or not.......
5helpful
2answers
The printer won't connect to my wireless network
I had the same problem. The issue was that the printer only accepts upper case letters for the network security pass phrase. However, my password was entered in lower case during the router set up.
I had to change the network password to upper case.
2helpful
I have a new Kodak ESP 7 printer and have not been able to set it up to communicate with my Mac OS 10.5 laptop. I can print if I have it plugged into the USB. I understand I might need an extra unit to...
Hi. I can help you connect your wireless ESP 7 to your Mac laptop.
The first step is to connect your printer to your wireless network. Navigate to the menu on the LCD of the printer and select Network Settings/WiFi Setup Wizard. The blue WiFi LED should be illuminating steady if the printer is connected to your WiFi network.
The second step is to add the WiFi printer to your Mac using the Print & Fax System Preference...
1. Under the Apple Menu, select System Preferences
2. Select Print & Fax
3. Click the "+" sign to add a printer
4. Select the Kodak ESP 7 listed with the Bonjour connection
5. Click the Add button.
The final step is to verify that you are printing to the WiFi printer when you attempt to print. In the Print Dialog box, verify the selected printer is named "KodakESP7+1234" where the last four digits are unique to your printer. If the printer you have selected is "Eastman Kodak Company KODAK ESP 7 AiO", then you are attempting to print using USB and this will not work unless you have a USB cable connected.
I hope this helps.
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
