SOURCE: Horizontal lines running through pictures.....Z612.
I just got my camera back from a repair shop, and I had the same problem. It's lens shutter damage. My camera was dropped while on vacation and suddenly got horizontal lines through every pic.
Unfortunately, the shop could not repair this and suggested I send it in to Kodak. Good luck
SOURCE: Kodak Z612 won't turn on
while you turn try and turn it on slow twist and pull lens outwards(gently while power on /off) and it will retract back in and power on.Work perfectly after.
Enzomatrixx Da Gr8 One
SOURCE: Kodak EasyShare Z612 will not format SDHC 4.0 GB
Z612 is not compatible with SDHC card., the compatible and recommended Memory card you can only used is 1GB SD card or 2GB SD card. Gudluck!
SOURCE: i have a sandisk sdhc card but it wont format on
The Z612 uses SD or MMC cards. It will not accept SDHC cards. You'll need to use cards 2GB and smaller.
SOURCE: How can you format a SD 4gb card for the Kodak
You can't. The Z612 uses SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card and is incompatible with SD devices.
For SD cards (2GB and smaller), you'll find the Format operation in the Setup menu. Press the Menu button, then use up/down to select the wrench, then press OK.
I have the same problem...looking for an answer. battery is fully charged and camera work fine outside. when i use it inside the flash pops up but does not flash wen i take the picture.
