Question about Lexmark T642 Laser Printer
I have a Lexmark T642. Where does the felt strip
I have a Lexmark T642. Where does the felt strip thingee go that comes with the toner cartridge? The manual does not tell me.
    New Friend:
The felt strips were not put in on the Newer T 630/T640 and up series as they were causing scoring on the fusers. They would act like sand paper and score it beyond use. There are no more which is a great thing.
Posted on Mar 08, 2010
SOURCE:
Lexmark T642 print gray though new cartridge
The main cause of light print is a bad set of charge and transfer rollers. These rollers are used to put a charge on the paper and transfer the toner to the charged paper. When the rollers get worn out they can not put the proper electrical charge on the paper so the toner does not stick to it as it should. One roller sits under the toner cartridge and on is on top on the cartridge. If you pull out the toner and look inside the printer you will see the transfer roller and if you start to close the lid with the toner out you will see the charge roller come into view. Here are pictures of each one. Transfer roller first.
These rollers come in the preventative maintenance roller kit. This kit is available at the following link. The kit also comes with the pickup rollers.
http://www.ccl-la.com/catalog/product_info.php?products_id=301
Jan 25, 2013 | Lexmark T642 Laser Printer
Lexmark T642 929.00 Service toner Sensor
The most common cause of this error is the toner cartridge. For more details on how to troubleshoot this problem, please click on the below.
http://bitly.com/oTXG4M
If you need further assistance please contact Lexmark Technical Support.
Oct 17, 2011 | Lexmark T642 Laser Printer
T642 æ??印æ?¶å?ºç?°ï¼? 929.00 service toner
f you are looking for the Lexmark printer driver then ;
You can download the Lexmark printer drivers from theirsupport WEB site.
Please click on this link and select your model printer todownload :- http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Jan 08, 2011 | Lexmark T642 Laser Printer
My lexmark T642 printer is printer lines at the far end of my invoices. Is this just a simple cartridge replacement?
It can be the cartridge or the dual charge roller. This roller is located above the cartridge. Take out the cartridge and lower the front cover 1/2. then you can see the dual charge roller. Partnumber 40X0127
Dec 14, 2010 | Lexmark T642 Laser Printer
How do I clean the heads on a Lexmark T642 as it is starting to leave large ink drops on the paper
A T642 has no "heads"as in an inkjet. "Drops" on the paper are mostly caused by a leaking cartridge. So try replacing the cartridge.
Oct 06, 2010 | Lexmark T642 Laser Printer
T642 Laser Printer: How do I change toner to my Lexmark T642. I can't ...
Switch off the printer and let the printer cool down. Then on the front of the printer open the release latchand lower the multipurpose feeder then open the top cover by releasing the latch. You will be able then to pull out the print catridge. Hope this helps.
May 03, 2010 | Office Equipment & Supplies
200.13 paper jam
that is referring to a jam under the toner cartridge..are you using genuine lexmark toners??
Jan 07, 2010 | Lexmark T642 Laser Printer
Lexmark T642 - print is very light
take the cartridges out and clean the spot they go into then clean them off also
Jan 19, 2009 | Lexmark T642 Laser Printer
Printing Issue - Lexmark T642
Chip on toner is bad, try puting in old one to reset and switch it with new one, sometimes turning off and on several times helps.
Mar 12, 2008 | Lexmark T642 Laser Printer
Lexmark T642 Laser Printer Logo
302 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
