Swiss Army Wenger Commando 70728 Wrist Watch Logo
Anonymous Posted on Feb 26, 2010
Stuck second hand
Hello - I received this as a gift last June purchased from Costco store(or very similar model). Not long ago, I noticed it stopped working for no apparent reason, but the second hand seems to 'tick' in-place slightly. The larger second hand on the stopwatch still works so the battery seemingly still works. Any ideas or should I try to contact Wenger for warranty repair? thanks
  • Anonymous Jul 05, 2010
    Thanks - replaced battery and thing did it again soon after. I took it back to Costco for full refund and no questions. Picked up a similar style Invicta. Excellent watch - no problems for 4 months counting.--
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Feb 26, 2010
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1812947
Points
13579
You need a new battery, as there is not enough power to move both gears. You can send it back to Wenger and get battery replaced or just pop into your nearest watch repair shop and get it replaced. It will cost you $5.oo and will be done in 10 minutes time instead of months of waiting it back from Wenger. Rate me, plz.
Just purchased the men's Citizen's Eco Drive Nighthawk (Black) ca0295-58e and the second hand on the watch is not ticking. I previously set the date and the hour and minute hands have moved, but not much....
Put the watch in any form of light for some time. Sun is best but not necessary. When the second hand stops running, it is a sign that the capacitor is low. The eco drive is a solar powered watch. When exposed to light, it converts the energy from the light and stores it in an internal capacitor which is really a battery that will last about 20 years.
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
1helpful
I just recieved a tissot pcr 200 as a gift and the large second hand is pointed to 12 doesnot move the small second dial is working as are the hour and minute hand
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
1helpful
Brand new watch - received for Christmas, and keeps lossing time
Dear cathy webb,
There could be many reasons for this. Maybe the battery is damaged/old, maybe it has another type of technical problem. Thats why i would suggest to you the same thing that i would do; send it to a repair shop. It usually costs between 7-15 US dollars to get it fixed, and it can usually be done for a couple of hours. As i see you have received this watch as a gift. Have you received the whole box including warranty card and the purchase receipt? In case you have received those, you could try and retrieve the watch to an official CK dealer, and maybe they will give you a new one or repair it for free. CK watch warranties are for one year and your watch is still covered by it (assuming it was purchased less than 1 year ago). I am not aware from what country you are, but some of the official CK Watch stores can be contacted here: http://www.calvinkleininc.com/watchesandjewelry/stores.aspx
Hope i could help, Regards
1helpful
We bought the Fossil Brown rectangle watch model FS4284, it stopped working so thought it was the battery. we replaced the battery and then 2 months later it's not working again, faulty battery or is...
  • Change the battery. If your watch stops ticking, chances are the watch is not broken and the battery simply needs to be replaced. You can purchase a watch battery at your local department store or drugstore. Use the screwdriver to pry the back off the watch and place the new battery in the same place where the old one fit.
  • Step 2 If your watch is still not working, determine the problem. If you can hear the watch ticking but the hands are not moving, there may be a gear stuck inside. If only one of the hands does not move, the hand itself could be broken. Once you determine the problem, you can see whether it makes more sense to purchase a new watch or get the old one fixed.
  • Step 3 Check your watch warranty. If your Fossil watch came with a warranty that is not yet expired, Fossil will fix your watch if you send it to the company and pay for shipping and handling. See the "Resources" section below to fill out the Watch Repair Form provided by Fossil.com. If your watch strap is broken, however, Fossil will charge you a fee as broken straps are not covered in the warranty.
  • Step 4 Check a competing local watch repair store. There are watch repair stores located all over the United States that will repair a Fossil watch if your watch is no longer under warranty or if you do not want to pay the shipping and handling to send the watch to Fossil's watch repair department. Although the watch repair store may not have the exact strap you are looking for, it may offer a replacement strap that is similar to the one that originally came with your watch.
  • Step 5 Return the watch to the store where you bought it. If you purchased a Fossil watch that was broken when you purchased it or broke recently after you brought it home, you may be able to return the watch for a refund or store credit. Check with the store's policy before purchasing the watch if you are concerned about returns.
  • 38helpful
    2answers
    Tag Heuer Link, stopwatch seconds hand stops 2 seconds before 12
    Pull crown out to position 2 [in between unscrewed (1) and pulled all the way out (3)].  Tap Button B (bottom) to reset by step back to zero.
    Incidentally, Button A works Hours register in same manner for position 2.  You can similarly reset second and 1/10th with Buttons A and B, respectively, while in position 3.  Cheers!
    2answers
    Is My Battery Dying?
    Do not think so. But try another battery and see what the result is - you might get lucky. If it continues to do the same you will have to accept the obvious - something is bogus with the unit.
    Watch not charging?
    Hi there.
    There are two types, A kinetic rechargable one, and a solar one.
    Just check it is the solar one!
    Try wearing it for a day and see if there is any change at all.
    If it does nothing, there may be a fault with the rechargable battery. If so , it is cost effective to have this repaired.
    3answers
    The second hand is not moving
    Got the same problem guys. i have one of the new electronic diving eco drives.
    First time i managed to get it going again, by forcing all the hands to the top for diving mode, then back to normal, this action ´nudged´the minute hand back into motion, but a little later it stuck again at the same spot.
    I guess mines going back to the factory, and i´m gonna b watchless for a few weeks :(
    Top Swiss Army Wenger Watches Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Swiss Army Wenger Watch Expert? Answer questions, earn points and help others
