My computer will inexplicably lose internet connectivity (the wireless signal). 15 minutes later or so, it will recognize the signal again, while im not connected, my signal does not appear as an option while other secure networks do?
modem and router connections appear to be working and hooked up correctly. Especially considering the signal re-appears on its own.
I'm thinking its a setting on my computer that is causing the problem, i could be way off though.
Re: xomputer will inexplicably lose the signal. A few
I think the problem must be with the router. When it drops the connection, you can see other networks but not yours. that means at that time the wireless signal on your router must not be broadcasted. WRT160N router has issues with the firmware. Youcan try to upgrade the firmware of the router. firmware is the software of the router. Once you upgrade the software, unplug the power to the router and plug it back in. wait for a moment and now observe the connection. Click here for more information about the router and internet
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
You may have an IP address conflict with another machine. why don't you just plug the router into the computer to see if that solves your problem first. If it doesn't. you should contact your internet carrier. You can also try this: turn everything off, and unplug EVERYTHING for a few minutes. Plug the AC adapters back into the devices FIRST, then into the wall. this will often drain power and solve IP issues.
I too am a gamer, it is not only important to have your connection be reliable and consistant speeds, but to have the game set up properly, full upload and download speeds set as default for in game. I would recommend getting a cat5 cable from the store and getting rid of wireless for the gaming computer. Try visiting some of the speedtest sites, depending on where you live you should try www.chi.speakeasy.net just click on the location closest to you, try it a few times, see if the speeds are what your paying for. check your bill or call your internet service provider and ask them what your paying for, if your not getting what you paid for most of the time you can negotiate the amount you pay for the next few months. most of the time free. As well as set up a tech to visit your house to make the signal frequency for the desired speeds.
does this happen when you're connected through a wired connection?
