Yamaha RX-V463 Receiver Logo
Posted on Feb 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to control Zenith DTT900 box with Yamaha RX-V463 remote
There is no remote control code listed for Zenith or Insignia digital converter boxes in the Yamaha RX-V463 manual. I have a DTT900 Zenith box that I would like to control with the Yamaha receiver's RAV280 remote. Can someone provide the correct code?
Anonymous
Level 2:
Champion:
  • Expert 312 Answers
  • Posted on Jul 02, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
312
Questions
0
Helped
126344
Points
418
Since Insignia and LG share compatible codes for digital-to-analog converters, review your remote control's manual for LG VCR codes as they should work to control the Insignia converter.
3answers
Ineed a code for tv converter box,What would the code be for a tv converter box ?
Different brand converter box will have differen tset-up codes. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Need 3 digit code for a zenith DTT900 CONVERTER BOX
373 664 851 852 859 864 865.
Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
I own an Insignia flat screen tv, NS-LCD27, & I was given the Insignia converter box, NS-DXA1; how do I program tv remote for the box? Thanks, frances b.
The digital to analog converters did not exist when the TV was built and the remote programmed. Thus you will have more luck programming the converter box's remote to control the TV. (At least with my converter box, the included remote could only turn on and off the TV. It would only change channels on the converter.)
Most universal remotes only have codes for devices released 6 months or more before the TV was programmed. So a new universal remote will probably control both the TV and the converter box. (Program the converter box using a code for LG or Zenith set top boxes if Insignia isn't listed. LG makes Insignia video products for Best Buy.) The remotes that are programmable by a USB connection to a computer are the fastest to set up.
A replacement remote for your TV is available here: http://www.mcmelectronics.com/partfinder.aspx?brand=&mdl=NS-LCD27&mode=part . An exact replacement remote for the converter box can be purchased at: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13055197980390&smodel=NSDXA1&brand_pn=INSIGNIA_NSDXA1 . The manual for the converter box (as a PDF) is here: http://cbsdallas.files.wordpress.com/2011/01/insignia-ns-dxa1-manual.pdf .
I hope this helps.
9helpful
5answers
3helpful
5answers
I am trying to find a universal remote code to control the new Zenith digital tv tuner converter box. The model # is DTT900. It is for a person with low vision who cannot see the buttons on the remote...
Pls post back with the brand and model of the universal (replacement) Remote Control or what remote control you would want to use with the Zenith DTT900 Digital-to-Analog Converter Box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Remote control code
What type of remote and model # and I will look the code up for you.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
